using c++ to write HAL module in linuxcnc
16 Mar 2021 14:25 #202479 by mikeshan97
using c++ to write HAL module in linuxcnc was created by mikeshan97
I'm new to linuxcnc, and I currently want to implement a chatter detection module as a linuxncnc HAL module.
the data acquisition module is written as a hal module already, and it uses C.
my plan is to write another CPP module since there is a more comprehensive library on digital sensor processing. And then using the data acquired from the above module via shared memory to calculate a bool variable that represents if the machine is in a chatter state or not.
Can someone tell me if there is anything wrong with my plan? Or any other advice is welcomed!
17 Mar 2021 00:31 #202551 by Roiki
Replied by Roiki on topic using c++ to write HAL module in linuxcnc
Depends if you're talking about realtime or userspace components. Realtime components have to be written in C. For userspace you should be able to use C++ with the C api.
17 Mar 2021 07:49 #202568 by Grotius
Replied by Grotius on topic using c++ to write HAL module in linuxcnc
Hi Roiki,
If you want to compile with c++ you need to install the linuxcnc dev files.
And you need the linuxcnc compile flags :
To compile your c++ code, this should be enough :
INCLUDEPATH += yourpath/linuxcnc/src/hal/utils
LIBS += -Iinclude -Isrc/emc/rs274ngc -Llib -lnml -llinuxcnc -llinuxcnchal -llinuxcncini -DULAPI -lposemath
17 Mar 2021 07:56 #202569 by mikeshan97
Replied by mikeshan97 on topic using c++ to write HAL module in linuxcnc
Thanks for your advice! I'll keep that in mind!
Time to create page: 0.105 seconds
