Open Loop Spindle control with DYN4
- BeagleBrainz
- Visitor
31 Mar 2021 01:45 #204163
by BeagleBrainz
Open Loop Spindle control with DYN4 was created by BeagleBrainz
Ok so I have a DYN4 servo drive & motor I'm using on my mill. Johnnycnc has given me a good starting point, forum.linuxcnc.org/12-milling/39783-spindle-motor-advice
What I would like to do is just for the time being is run the motor in open loop.
Q1. Is this possible ?
Q2. What mods do I have to make to the hal file ?
Relevant section of HAL, in my hal I've made changes to reflect the 7i92 I'm using and such.
Any help or suggestions would be great.
# SPINDLE S
setp pid.s.Pgain [SPINDLE_0]P
setp pid.s.Igain [SPINDLE_0]I
setp pid.s.Dgain [SPINDLE_0]D
setp pid.s.bias [SPINDLE_0]BIAS
setp pid.s.FF0 [SPINDLE_0]FF0
setp pid.s.FF1 [SPINDLE_0]FF1
setp pid.s.FF2 [SPINDLE_0]FF2
setp pid.s.deadband [SPINDLE_0]DEADBAND
setp pid.s.maxoutput [SPINDLE_0]OUTPUT_MAX_LIMIT
setp pid.s.error-previous-target true
net spindle-index-enable <=> pid.s.index-enable hm2_5i25.0.encoder.00.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm => pid.s.command
net spindle-fb-rpm => pid.s.feedback
net spindle-output <= pid.s.output
# ---Analog output signals/setup---
setp hm2_5i25.0.7i83.0.1.analogout5-scalemax [SPINDLE_0]OUTPUT_SCALE
setp hm2_5i25.0.7i83.0.1.analogout5-minlim [SPINDLE_0]OUTPUT_MIN_LIMIT
setp hm2_5i25.0.7i83.0.1.analogout5-maxlim [SPINDLE_0]OUTPUT_MAX_LIMIT
net spindle-output => hm2_5i25.0.7i83.0.1.analogout5
net spindle-vel-cmd-rps <= spindle.0.speed-out-rps
net spindle-vel-cmd-rps-abs <= spindle.0.speed-out-rps-abs
net spindle-vel-cmd-rpm <= spindle.0.speed-out
net spindle-vel-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-enable <= spindle.0.on and2.ena.in0 estop-latch.1.reset
net spindle-cw <= spindle.0.forward
net spindle-ccw <= spindle.0.reverse
net spindle-brake <= spindle.0.brake
net spindle-revs => hm2_5i25.0.encoder.00.position spindle.0.revs
net spindle-vel-fb-rps => spindle.0.speed-in
net spindle-index-enable <=> spindle.0.index-enable
net spindle-lockout-db estop-latch.1.ok-out => and2.ena.in1
net spindle-OK and2.ena.out => timedelay.0.in
net DYN-enable timedelay.0.out => hm2_5i25.0.7i76.0.0.output-03 hm2_5i25.0.7i83.0.1.analogena5
net spindle-Lockout hm2_5i25.0.7i76.0.0.input-07-not => estop-latch.1.fault-in
net spindle-vel-cmd-rpm-abs => near.0.in1
net spindle-fb-rpm-abs => near.0.in2
net spindle-at-speed spindle.0.at-speed <= near.0.out
setp near.0.scale 1.04
# Use ACTUAL spindle velocity from spindle encoder
# spindle-velocity bounces around so we filter it with lowpass
# spindle-velocity is signed so we use absolute component to remove sign
# ACTUAL velocity is in RPS not RPM so we scale it.
setp scale.0.gain 60
setp lowpass.0.gain .007
setp lowpass.0.load false
net spindle-vel-fb-rps hm2_5i25.0.encoder.00.velocity => scale.0.in
net spindle-fb-rpm scale.0.out => abs.0.in
net spindle-fb-rpm-abs abs.0.out => lowpass.0.in
net spindle-fb-rpm-abs-filtered lowpass.0.outPlease Log in or Create an account to join the conversation.
- Michael
- Thank you received: 59
31 Mar 2021 19:31 #204275
by Michael
Replied by Michael on topic Open Loop Spindle control with DYN4
On the surface it doesn't look bad but you would need to know how you plan on controlling the spindle. What card are you using (7i76, etc)? Will you be using +/-10v or 0-10v? Will the spindle be geared? Why not add the encoder?
Also there are a number of components you are using that will need to be loaded in the hal. They are most likely at the top of the hal file but we only see the spindle section. Most likely look like this:
loadrt abs names=abs.spindle
loadrt lowpass names=lowpass.spindle
loadrt scale names=scale.spindle
- BeagleBrainz
- Visitor
31 Mar 2021 21:19 #204306
by BeagleBrainz
Replied by BeagleBrainz on topic Open Loop Spindle control with DYN4
As the snippet shows I’m using a 7i83.
I figured that there are some components that won’t be needed.
The reason I don’t want to add the encoder ATM as it will take some time to get the right cable to connect the DYN4 encoder output to my 7i76.
The wiring from the encoder on the spindle motor to the driver is sorted.
- Michael
31 Mar 2021 21:53 #204317
by Michael
I assumed the hm2_5i25.0.7i83.0.1.... was a copy and paste of the person you mentioned hal. If this is your actual hal then the 5i25 will need to be replaced with the 7i92.
How did you get the hal file to this point? If you are copying and pasting from someone else you may encounter errors unless their setup is exactly the same, which it doesn't appear to be. You can go through pncconf and setup a spindle with no feedback. That will get the hal completed perfectly. Otherwise I would recommend checking all of this by configuring hal in a terminal: linuxcnc.org/docs/2.8/html/hal/tutorial.html#_a_simple_example
Either way you will need to double check that the pins you have listed in this hal example actually exist on your machine. Thats why I mentioned you are missing a bunch of loadrt. It may be at the top but if it isn't then many of the pins you have on the list won't be there.
- BeagleBrainz
- Visitor
31 Mar 2021 22:37 #204324
by BeagleBrainz
OK.
The machine I'm using has no internet, and I was lazy and did just copy and paste the snippet, as I said I was using it as a reference, which I thought would imply I made the changes required. Hell my 7i83 is on the second sserial port and a different channel.
Yes I have changed the the hal lines to resemble my machine, the hal file loads and linuxcnc starts. So obviously the components are being loaded. And no I'm trying to use the vcp Johnny is using, so no need to mention that. That is not the issue, that was not even my question.
All I asked was whether it is possible to run the spindle open loop and if it was, what changes are required.
I'm familiar with hal, my full hal file includes a custom component I wrote for my pendant.
I'm even using a custom Mint ISO that I used to distribute and supply updated packages for. I'm just unfamiliar ATM with spindle control. The machine has been running for a couple of years, first with Mach3, then Machinekit on a BBB with custom breakout boards, then with a J3355B and my mesa hardware, now I've switched over to a Odroid H2+ and a completely rebuilt control cabinet. The decision to add spindle control was the reason for the rebuild.
I looked a pncconf and really didn't see a an option to configure the spindle without feedback, maybe I missed something.
- Michael
31 Mar 2021 22:39 #204325
by Michael
Seems you got it figured out then
- BeagleBrainz
- Visitor
31 Mar 2021 23:36 #204332
by BeagleBrainz
No.
I still need a bit of advice in going from a closed loop to open loop config.
No.
02 Apr 2021 22:42 #204566
Set P, I, D FF1 and FF2 to zero.
Then adjust FF0 to get the correct speed.
Replied by andypugh on topic Open Loop Spindle control with DYN4
The following user(s) said Thank You: BeagleBrainz
- BeagleBrainz
- Visitor
03 Apr 2021 02:29 #204588
by BeagleBrainz
Ok so I still need PID that's great to know.
Had it running last night on the test bench, feeding (using correct hal notation)
spindle.0.speed-out straight to hm2_7i92.0.7i83.1.5.analogout5 and was able to get movement, the 7i83 was supplying a calculated voltage that was correct.
Does the above look right or am I wayyyyy off ? (assuming I have loaded pid.s)
Eventually the encoder output from the servo driver will get connected up, just need to get hold of a small amount of 3 pair shielded twisted pair.
# SPINDLE S (open loop)
setp pid.s.Pgain 0
setp pid.s.Igain 0
setp pid.s.Dgain 0
setp pid.s.bias 0
setp pid.s.FF0 "adjust to suit"
setp pid.s.FF1 0
setp pid.s.FF2 0
setp pid.s.deadband 0
setp pid.s.maxoutput 4000
#net spindle-index-enable <=> pid.s.index-enable hm2_7i92.0.encoder.00.index-enable
#net spindle-fb-rpm => pid.s.feedback
setp hm2_7i92.0.7i83.1.5.analogout5-scalemax 4000
setp hm2_7i92.0.7i83.1.5.analogout5-minlim -4000
setp hm2_7i92.0.7i83.1.5.analogout5-maxlim 4000
net spindle-output => hm2_7i92.0.7i83.1.5.analogout5
net spindle-vel-cmd-rpm <= spindle.0.speed-outDoes the above look right or am I wayyyyy off ? (assuming I have loaded pid.s)
- johnmc1
- Thank you received: 21
03 Apr 2021 12:10 #204615
by johnmc1
Replied by johnmc1 on topic Open Loop Spindle control with DYN4
Have you enabled analog5 elswhere.
