using a Gecko540, uc300eth_5lpt, and a THCAD-10 with plasmac
31 Mar 2021 18:44 #204256 by alombardi
Hi everyone,
Just to give you a little context, I currently I have a 4' by 6' plasma table with Gecko540, UC300eth_5lpt, C10-D i/o expansion board from CNC4 PC and a Neuron Simplicity THC with UCCNC software. Everything works fine except the THC.
It's time for a change. I would like to try LinuxCNC and PlasmaC. Can the THCAD-10 and THCAD-5 be used with my setup without investing in a Mesa 7I76E card?
02 Apr 2021 20:44 #204557 by andypugh
Possibly, if the software encoder can count the pulses fast enough.
" The THCAD has a frequency output range of approximately 100 KHz to 1 MHz. T his can be counted directly by our FPGA cards for conversion to voltage value. The frequency output can optionally be divided by 32, 64 or 128 if the output must be counted in software."
So if your hardware can manage a 1MHz / 128 = 8kHz base thread then you should be OK.
  • Moderator
  • Moderator
02 Apr 2021 21:24 #204561 by tommylight
UC300eth_5lpt
will not work with LinuxCNC as far as i can tell.
03 Apr 2021 11:20 #204608 by alombardi
Thankyou very much.
Time to create page: 0.175 seconds
