adding debounce
03 Apr 2021 21:46 #204673 by motal2004
adding debounce was created by motal2004
Hi people.
I need a little bit of hand holding here...
I need to add from the PlasmaC document state , “extra filters”,debounce to my home switches. Do I do that in the connection hal file & what would that look like ?
Thanks,
03 Apr 2021 22:47 #204678 by robertspark
03 Apr 2021 22:58 #204680 by motal2004
Replied by motal2004 on topic adding debounce
Thanks for that information, I’m running a Mesa 7i96 board. I Will keep digging.
05 Apr 2021 23:59 #205002 by andypugh
Replied by andypugh on topic adding debounce
Just swap 7i77.pin-name to the equivalent 7i96,pin-name.
I say "just". There is a little bit of thought needed to work out how your pin names map to the example.
The following user(s) said Thank You: motal2004
