G71
5 years 6 months ago #205066 by rider-83
G71 was created by rider-83
What would be my simplest option to obtain G71 cycle?
I hear that ver2.9 has it built in. Is this my best route?
5 years 6 months ago - 5 years 6 months ago #205185 by andypugh
Replied by andypugh on topic G71
rider-83 wrote: I hear that ver2.9 has it built in. Is this my best route?
Yes.
See buildbot.linuxcnc.org for instructions on how to start using the dev version.
Last edit: 5 years 6 months ago by andypugh.
5 years 6 months ago #205264 by rider-83
Replied by rider-83 on topic G71
Would it be as simple as:
Make a back up copy of my config folder with the .HAL and .INI files
Install/replace my ver 2.7 with 2.9
Then copy over the backup folder?
5 years 6 months ago #205292 by andypugh
Even simpler. Make a backup copy of the configs just in case. But they won't be overwritten.
A script will ask to run to update the 2.7 config to the 2.8 format.
5 years 6 months ago #205454 by rider-83
Will it have any effect on my current Lathe set up, will everything stay as they were?
5 years 6 months ago #205456 by andypugh
Everything should "just work". But make a backup of the config folder just in case.
