G71
4 years 4 months ago #245432 by DoWerna
Replied by DoWerna on topic G71
i ask myself the same question. my lathe is getting ready now.
runs with LCNC 2.8.2 Gmoccapy and the lathe macros from andy.
g71 and g72 would really be a great added value.
I only have the home user version fusion360, I often make cylinder heads for two-stroke engines. (the combustion chamber)
Would rather write the gcode myself instead of setting up fusion.
How stable is buidbot 2.9?
Don't want to break my working setup.
will the macros work under 2.9
or, is it predicteble when 2.9 will be released normally?
4 years 4 months ago #245565 by andypugh
Replied by andypugh on topic G71
Fairly stable.
From my testing last night, no they don't. This is a GTK3 issue that I have not managed to get to for over a year.
The following user(s) said Thank You: DoWerna
4 years 4 months ago #245586 by DoWerna
thanks andy .
so I stay with 2.8.2, I do not want to lose the macros in any case.
They are too useful.
I'll try to set up fusion 360.
4 years 4 months ago #245667 by rider-83
Replied by rider-83 on topic G71
I upgraded to 2.9 for the use of the G71 cycles and had a real hard time. It really wasn't worth the trouble, so I had to revert back to 2.8.2
4 years 4 months ago #245668 by andypugh
What problems did you have? Was it general Linux problems or specific G71 problems?
4 years 4 months ago #245982 by rider-83
It's quite a while back now, so I don't remember exactly, but there where many issue with missing packages and a lot of manual work in order to get it to install correctly. After that the main issue was that the GUI woudn't re-size to match my monitor size and the menus were off the screen. I started a thread on this issu but got no where with it, so I abandoned it.
Time to create page: 0.333 seconds
