Get the value of a HAL component
08 Apr 2021 13:29 #205321 by elisa
Get the value of a HAL component was created by elisa
Hi to all,
I have a big question. How can I get the value of a HAL component from a Python script?
In the documentation I found the command "hal.get_value()" but it doesn't seem to work ..
Any suggestions?
Please write soon!
08 Apr 2021 16:21 #205333 by MaHa
Replied by MaHa on topic Get the value of a HAL component
This reading the actual value, s2n2 is a signal
px=hal.get_value("s2n2")
The following user(s) said Thank You: elisa
08 Apr 2021 16:45 #205335 by andypugh
Replied by andypugh on topic Get the value of a HAL component
How does it not work?
You may need "import hal" and you may also need "import linuxcnc"
You can set up your Python script to create its own HAL pins, then use those as variables in your script without having to poll them.
08 Apr 2021 21:11 #205366 by elisa
Replied by elisa on topic Get the value of a HAL component
I forgot to add "import linuxcnc".
Now It works, thank you ALL!
08 Apr 2021 22:58 #205380 by cmorley
Replied by cmorley on topic Get the value of a HAL component
hmm I wouldn't of expected to need to import linuxcnc for HAL pins to work...
08 Apr 2021 23:01 #205381 by cmorley
It's not required in python 2
Time to create page: 0.233 seconds
