Invertek VFD RS485 Control
- Scrappycnc
16 Apr 2021 03:13 #206079
by Scrappycnc
Invertek VFD RS485 Control was created by Scrappycnc
Hi all, I'm having a bit of a time understanding the MODBUS RTU control for my invertek optidrive e2. I've got vfdmod aekhv installed to support the generation of the .ini file. However I'm not having a great time deciphering the registration map from my drive to hex addresses that make sense. I've attached the map from invertek here, if anyone can point me in the right direction, I'd appreciate it.
- Thank you received: 4652
16 Apr 2021 23:13 #206145
Replied by andypugh on topic Invertek VFD RS485 Control
Where did you find "vfdmod aekhv" That isn't core LinuxCNC code, so we at least need more info on what it is.
is it an _exact_ match for your VFD?
- Scrappycnc
20 Apr 2021 17:32 #206549
by Scrappycnc
Replied by Scrappycnc on topic Invertek VFD RS485 Control
It is not an exact match in terms of the default or parameters included, but it appears that the .ini file is configurable to allow for parameters that support my VFD. VFDMOD files can be found
here
. I think I'm needing help with understanding the HEX coding of my VFD, but there is a good chance that I need to understand more.
21 Apr 2021 11:19 #206632
There is also linuxcnc.org/docs/devel/html/drivers/mb2hal.html
Whether that helps, or just adds more confusing options I can't guess.
- Scrappycnc
25 Apr 2021 02:46 #206989
by Scrappycnc
Thanks, I'll check this out.
Time to create page: 0.092 seconds
