Problem with moving form 8.04 to 10.04 etc
- grey1beard
17 Sep 2010 09:27 - 17 Sep 2010 10:46 #4227
by grey1beard
Problem with moving form 8.04 to 10.04 etc was created by grey1beard
Having been off the m/c for some months, I return to find that "EMC2 is supported by 10.04" etc.
Saved my config file onto a pendrive, then after many trials finally got 10.04 to run on the workshop system.
Installed EMC2 ver 2.4.3, and imported my config file first onto the desktop, then into the config folder in the emc folder.
Opened the stepconfig wizard to see if the settings were as I remembered them(memory, what memory ? ), and tried "Test this axis".
Nothing on any axis, and no sound of the motors being energised.
I tried running EMC2 from the application menu/config selector and got a quick view of the Axis screen before a had a screen "EMC2 errors".
"Please include all the information below in your message" but I've no idea how to copy that over into this post. There's a select all button, but no copy, so if someone can tell me how to do that first, I'll edit this post and include it.
Many thanks
EDIT Just in case there was something wrong with my saved settings, I've tried creating a new config file, but the results are the same.
Many thanks
Last edit: 17 Sep 2010 10:46 by grey1beard. Reason: updated info
17 Sep 2010 16:02 #4234
by Andy123
Replied by Andy123 on topic Re:Problem with moving form 8.04 to 10.04 etc
I feel that you are on the same boat with many other old users:
www.linuxcnc.org/component/option,com_ku...d,4082/lang,english/
- grey1beard
17 Sep 2010 16:18 - 17 Sep 2010 16:21 #4235
by grey1beard
Replied by grey1beard on topic Re:Problem with moving form 8.04 to 10.04 etc
Andy123 wrote:
Hi Andy,
Yes, been there - read that - understood very little, still being wet behind the ears
Just been reading through "Ubuntu Pocket Guide & reference" by Keir Thomas, and at least I've found out how to copy/paste without a copy button !
So this is the error file.
ooops, no it isn't. I'll try again
Hi Andy,
Last edit: 17 Sep 2010 16:21 by grey1beard.
- grey1beard
18 Sep 2010 07:01 #4240
by grey1beard
This may be a more general problem.
I've just tried opening the sample config for sherline 3axis, and I get exactly the same error window, and simillar file.
Do I have to go back to an earlier version of emc2, as this one is not going anywhere at the moment ?
18 Sep 2010 10:18 #4241
by micges
Replied by micges on topic Re:Problem with moving form 8.04 to 10.04 etc
try setting [EMC]DEBUG =0x7FFFFFFF and again paste whole terminal output
- grey1beard
18 Sep 2010 10:26 #4242
by grey1beard
Sorry, micges, I've removed everything and am currently downloading the 10.04/emc iso for a combined install.
I'm hoping this might give me a better experience than installing them separately
I'll post here again when I have the result, probably this pm.
- grey1beard
18 Sep 2010 17:26 #4244
by grey1beard
No, everything is just as bad with this release, so I've given up, and am now in the process of updating my original 8.04/emc2 download.
It went in perfectly, and so far has not shown any hiccups.
Time to create page: 0.178 seconds
