halviewer, go or no go?
- Grotius
- Thank you received: 2349
30 Apr 2021 17:10 - 30 Apr 2021 17:11 #207467
by Grotius
halviewer, go or no go? was created by Grotius
Accidentely i am building a halviewer. It interacts with hal on c and c++ level.
I had a few things to solve in c++ to get it running with the axis template gui.
This is a first preview of the program.
Red=bit off value
Green=bit on value
Orange=float value
Grey=To code, not finihed.
I was wondering. We could also set halpins, paramters, etc.
What would be a big improvement to the existing halshow?
Red=bit off value
Green=bit on value
Orange=float value
Last edit: 30 Apr 2021 17:11 by Grotius.
The following user(s) said Thank You: tommylight, elovalvo
- Thank you received: 7478
30 Apr 2021 17:15 #207469
Replied by tommylight on topic halviewer, go or no go?
Nice. Thank you.
- Grotius
30 Apr 2021 17:44 #207471
by Grotius
Replied by Grotius on topic halviewer, go or no go?
Hi Tom,
Can you think about what would be a mayor improvement for existing the halshow program?
For example it could be :
- a logger
- a curve printer
- etc.
Maybe you have a idea?
- a logger
- a curve printer
- etc.
30 Apr 2021 20:15 #207479
Sorry Groti, but i am way to tired to think about anything and will be so for 4 to 8 days more, trying to finish and install and paint and fix and setup ... everything in the new shop while getting another machine ready as it got sold last week. As luck would have it the guy wanted the one that takes most time to get ready!
I will for sure report if by any chance something runs through my mushy brain !
- Grotius
01 May 2021 21:26 #207574
by Grotius
Hi Tom,
Take your time. Succes with your new shop !
I integrated a treeview beside the tableview.
Most of the code is completed now. Have to do the "functions'.
You see in the middle there is space left.
Possible addon's :
- Maybe add a halscope there?
- Or a s-curve motion profile tester?
- Or a hal config builder?
Possible addon's :
01 May 2021 22:26 #207586
Scope !
01 May 2021 22:28 #207587
Graphical representation of the whole hal tree
(That might be difficult, though it has been done in Rockhopper, for example)
wiki.linuxcnc.org/cgi-bin/wiki.pl?Rockhopper_Web_Server
Replied by andypugh on topic halviewer, go or no go?
Possible addon's :
- pippin88
- Thank you received: 51
02 May 2021 09:32 #207609
by pippin88
Replied by pippin88 on topic halviewer, go or no go?
I'm interested, looks good
- Grotius
02 May 2021 11:06 #207614
by Grotius
Hi Tom,
Yes a scope is nice !
Hi Andy,
A halgraph or visual hal representation could be nice !
I don't have a clue how to add the arrow lines between items.
In general, i can try a new approach in 3d. This is more interesting for me to set up then a 2d graph.
For example to visulalize the standard axis gui, it has 18 components, 774 pins, 69 parameters, etc running
This is a huge ammount of data. It's almost a neural network.
Then we could integrate a 3d halscope with the same viewer. This can be quite interesting to see what happens.
Ok i will make a test today.
Hi Andy,
The following user(s) said Thank You: chris@cnc
- chris@cnc
- Thank you received: 140
02 May 2021 13:46 #207620
by chris@cnc
Replied by chris@cnc on topic halviewer, go or no go?
One great improvement would be the last search or last view function. and if the pins including pvcp are already pre-sorted in an axis view. then with little search you would have an overview of every axis or spindle.
Time to create page: 0.864 seconds
