halviewer, go or no go?
5 years 5 months ago - 5 years 5 months ago #207657 by Grotius
Replied by Grotius on topic halviewer, go or no go?
Hi Chris,
How about if a sheet only knows all your halfile pins and show the route with these blocks and colors horizontally.
This pins is what you see. It are the colored boxes.
I have to think about implementation some more.
Each item you see, can be clicked. When clicked i can code that is show's related data.
Attached picture is when halview is rotated to horizontal by the rotate box.
The blue lines are all the signals of the axis gui project.
This axis gui project has 31 signals. Each signal may contain readers and writers.
It isn't showing internal component connections lines from pin to pin, they are now invisible.
You see one component is huge. It's like a tower to the moon.
Last edit: 5 years 5 months ago by Grotius.
The following user(s) said Thank You: chris@cnc
5 years 5 months ago #207666 by chris@cnc
Replied by chris@cnc on topic halviewer, go or no go?
Hi Grotius
Yes i forgot, some components have lots of pins.
But the idea is very nice. Makes diagnosis easier for mechanics too. They always need pictures.:)
5 years 5 months ago - 5 years 5 months ago #207727 by Grotius
For now i have finished the program. You can download it to give it a try.
It has the watchlist :
1. The watchlist is auto saved.
2. The watchlist is loaded after program restart.
3. You can clear the watchlist.
It has a halcommand input and a halcommand verbose output.
During install it will create a desktop launcher into the system menu, and it will create a ldconfig to link the liblinuxcnchal.so.
So far as i can see it works.
Download .deb installer :
sourceforge.net/projects/halview/
The following user(s) said Thank You: tommylight, Aciera
5 years 5 months ago #207760 by andypugh
Replied by andypugh on topic halviewer, go or no go?
Maybe drop the pins that are not connected from the viewer?
5 years 5 months ago #207921 by Grotius
Hi Andy,
It shows the current loaded hal config. It's tested with a quite huge halconfig, the standard axis gui template.
A future plan could be using it to create hal files.
5 years 5 months ago #207961 by andypugh
Grotius wrote: Hi Andy,
I thought that it looked to be showing all pins of the loaded modules. I was suggesting only showing _used_ pins of loaded modules.
(Though you also want to be able to see unused pins, so you can see which ones need to be connected)
Time to create page: 0.268 seconds
