Setting up threading on a Boxford 160TCL lathe
01 May 2021 18:02 #207562 by rider-83
I see some members have set up screw cutting / threading on a Boxford TCL lathe.
I have a Boxford 160TCL fitted with a new spindle servo motor, and am currently configuring LinuxCNC 2.9
Encoding:
The original encoder disc is still fitted to the rear of the spindle, but the sensor is missing for some reason.
What would be my best option here? Should I use some form of sensor with this original disc, or find a completely different and new arrangement?
Parallel Port:
Because I no longer have any further input signals available with my current LPT port, I'm going to add another to the spare PCI slot and set it at either 'x' or 'in' .
Any thoughts here would be appreciated.
Nick..
01 May 2021 22:24 #207585 by andypugh
Replied by andypugh on topic Setting up threading on a Boxford 160TCL lathe
If the disc exists, then I would use it.
The original sensors were probably something fairly standard.
I think I would use something like uk.rs-online.com/web/p/slotted-optical-switches/6666473/ which has logic output so save messing about with pull-ups etc.
As there are 5 in the pack, you might as well do the full ABZ set for rigid-tapping support.
04 May 2021 14:05 #207829 by rider-83
Replied by rider-83 on topic Setting up threading on a Boxford 160TCL lathe
What would be my wiring requirements?
+5v & GND on two legs, and the others would connect direct to the LPT?
04 May 2021 17:07 #207852 by andypugh
With the ones I linked to, yes.
12 May 2021 17:12 #208632 by rider-83
Andy,
The optical switches you advised from RS have arrived. I'm going to start playing around with my test PC.
I have the emitter LED connected to +5DC & GND to an external power supply.
The three other legs, I'm a little lost. My thoughts were the GND to a GND pin on the LPT, but I'm unsure of the other two. It looks from the wiring diagram that I apply a further 5v and collect the signal from the middle pin?
12 May 2021 17:26 #208634 by andypugh
You probably didn't want to do that without a resistor to limit the current. The data sheet does not show any current limiting resistor and says that the LED has a max current limit of 50mA. I would suggest aiming for 5mA, at which point the LED forward voltage is 1,1V.
5V - 1.1V = 3.9V at the LED, V=IR suggests that a 680R resistor would be about right.
If you have already switched it on like that then the LED might well be dead now. You might be able to see if it is lit up in infra-red with your mobile phone camera.
Yes, that's right. You can connect the 5V to the same 5V as the LED (not via the resistor). And check that the output varies between 0V and 5V with a multimeter before connecting to the parallel port.
You could consider stealing the 5V from a USB port, then you can be sure that the port and the sensor share a power supply reference.
(just cut an end off of a USB cable, the red and black cores will be 5V and 0V.
12 May 2021 17:26 #208635 by andypugh
12 May 2021 18:49 #208641 by rider-83
I've just found on the internet a separate data sheet from 'Sharp'. They are suggesting a 47ohm resistor. How does that sound?
I like the idea of the USB 5v. This PC unit has loads of them.
I was running out of 5v options from my power supply, and the solution was right there in front of me,
Thanks once again :)
12 May 2021 21:44 #208660 by andypugh
It sounds low. V/R = 3.9 / 47 = 82Ma.
Are you sure it wasn't 470 ohms?
13 May 2021 05:22 #208703 by rider-83
Ive ordered 680's & 47's just in case. For the price of them its worth keeping them in stock.
Time to create page: 0.157 seconds
