Setting up threading on a Boxford 160TCL lathe
- Thank you received: 4652
22 May 2021 16:53 #209847
Replied by andypugh on topic Setting up threading on a Boxford 160TCL lathe
sudo apt get install pciutils
Some idiot left it out of the ISO image.
- rider-83
- Thank you received: 10
22 May 2021 17:10 #209849
by rider-83
Replied by rider-83 on topic Setting up threading on a Boxford 160TCL lathe
Guess what.
To add to the missing 'lspci' thingy
I've just found your thread on PCI cards, and I have that generic Chinese item that doesn't work.
The forces are against me at the moment!!
- Thank you received: 7468
22 May 2021 17:22 #209852
Replied by tommylight on topic Setting up threading on a Boxford 160TCL lathe
Try
loadrt hal_parport cfg="0x378 out 0x037b out"
in the hal file.
If LinuxCNC starts, all is good.
in the hal file.
- rider-83
22 May 2021 17:52 #209855
by rider-83
I've ordered two PCI cards with the MOSCHIP chip set. That will sort out that issue, and tomorrow I'll upload the 'pciutils', but for now I've just fitted a quiet silencer and throttle restrictor to my little girls motorbike bike and we are going to get a few practice laps in around the garden ready for when the sun comes out and she can ride with Daddy at the track
- Clive S
- Thank you received: 486
22 May 2021 18:11 #209856
by Clive S
That is more important the the threading. Good one
Replied by Clive S on topic Setting up threading on a Boxford 160TCL lathe
24 May 2021 21:35 #210112
Too late, but by the time you are ordering two parallel port cards you should probably be ordering one 5i25 / 6i25 card as that does all that two parport cards do, and _so_ much more. Plus they always work.
Time to create page: 0.175 seconds
