basic question about Driver input signals
14 May 2021 21:37 #208861 by acourtjester
basic question about Driver input signals was created by acourtjester
Hi
new to Linuxcnc not cnc, I am starting to wire up my Mesa 7I76E. Question is the signals to the drivers. On all the other table I built I wired the driver with Step + and gound, and Dir+ and ground. Now the 7I76E has +5 volts, step+ step-, dir+ dir- and gound. I did see a post here that said about the same as I used before, step + and ground for the stepper signals and Dir+ and ground for the Direction signals.
thanks for the help
Tom
14 May 2021 22:17 #208865 by tommylight
Replied by tommylight on topic basic question about Driver input signals
That should work OK.
Tom.
The following user(s) said Thank You: acourtjester
15 May 2021 03:07 #208885 by acourtjester
Replied by acourtjester on topic basic question about Driver input signals
thanks for the reply
15 May 2021 23:24 #209004 by andypugh
Replied by andypugh on topic basic question about Driver input signals
If the drivers have differential inputs then differential wiring will be more noise resistant.
What are the drivers?
15 May 2021 23:41 #209007 by acourtjester
one DM860A and 2 DM542T
16 May 2021 02:32 #209027 by rodw
Will be fine as proposed. Just leave the enable signals unconnected. they are a disable signal
16 May 2021 16:19 #209112 by andypugh
Both those drives have differential inputs, so I would wire them differential. Mesa Step+ to pulse+, step- to pulse-, and similarly for dir.
As has been said, there isn't a lot to be gained from wiring the enable with a stepper driver, it is just a waste of wire.
16 May 2021 16:31 #209115 by acourtjester
Thanks for the replies
16 May 2021 16:36 #209118 by rodw
My mistake. where you said step+ and ground, it should be step + and step - as Andy said.
16 May 2021 23:55 #209187 by rollfree
Replied by rollfree on topic basic question about Driver input signals
Neither driver has differential inputs (DM860A nor DM542T). Both drivers have ordinary inputs with an optocouplers. See picture.
cdn.goodao.net/longs-motor/7af08ace2.jpg
A better option is to connect only DIR +, STEP + and GND signals (or DIR-, STEP- and + 5V).
Time to create page: 0.665 seconds
