Is it OK to have odd numbers of pockets on ATC
- Clive S
- Thank you received: 486
15 May 2021 15:27 #208920
by Clive S
Is it OK to have odd numbers of pockets on ATC was created by Clive S
As the title: Is it OK to have odd numbers of pockets on ATC
I am making an ATC carousel and the biggest number I can fit is 15
I have only ever seen even numbers is there a reason for that ?
- Thank you received: 7468
15 May 2021 17:06 #208932
Replied by tommylight on topic Is it OK to have odd numbers of pockets on ATC
I Had with 8 and 12 and 16, so it does not matter.
- Clive S
16 May 2021 06:56 #209046
by Clive S
Thanks. But is there a reason why you don't see odd pockets numbers ie 13-15 -17
Replied by Clive S on topic Is it OK to have odd numbers of pockets on ATC
- phillc54
- Thank you received: 2100
16 May 2021 09:40 #209058
by phillc54
Sorry Clive, I couldn't help myself.
Replied by phillc54 on topic Is it OK to have odd numbers of pockets on ATC
Because it would be odd?
- Clive S
16 May 2021 10:58 #209066
by Clive S
Very funny
I have been told that there might be an issue with odd numbers of pockets.
There is a reason for me to have 15 and not 16 I could have 14 but I want to squeeze the extra one in.
With 16 on the disc the tools foul the mill column and clears with 15
Very funny
16 May 2021 11:38 #209074
I really do not think it has anything to do with anything, humans like even numbers, well except number 3 !
LOL
- Thank you received: 4652
16 May 2021 16:25 #209114
Not that I know of. But if you are building a tool coreousel with pocket position sensors then with 4 sensors you can have 16 pockets. Only having 15 pockets feels wasteful. And if you wanted 17 pockets then you would need 5 sensors, but only a single pocket would activate that sensor.
If you have a good reason to only have 15 pockets, then there is no reason to expect it to cause problems.
Replied by andypugh on topic Is it OK to have odd numbers of pockets on ATC
- Clive S
16 May 2021 18:19 - 09 Aug 2021 17:55 #209151
by Clive S
I will start a new post for help with the ATC
I am building my version of this ATC for PathPilot www.cnczone.com/forums/tormach-personal-.../417676-tormach.html
There is only two sensors to home the disc and the retract from the spindle. This use a Pye board that will emulate the Tormach usb board.
This is a link to what I have so far: photos.app.goo.gl/zwF3agZBmtnFT9gY8 I have fitted the index homing sensor (not shown)
The disc is a bit of a mess as I have drilled it 3 times 14 then 16 and now 15 pockets. I will clean it up
I am not sure if PP will show the 15 pockets I know it does 8 and 10
I do appreciate your comments. Thanks
Last edit: 09 Aug 2021 17:55 by Clive S.
Time to create page: 0.098 seconds
