Stepper motors run free when enable is inactive
- Gordon49
- Thank you received: 5
17 May 2021 20:37 #209279
by Gordon49
Stepper motors run free when enable is inactive was created by Gordon49
I have just had to change my BOB and the pin settings are a little different - which is a simple matter to change. However when the EStop is triggered or the motor on button is off the stepper motors are free to turn manually. As this did not happen with my old board I wonder which is the more normal occurrence. Or have I just missed something? Wiring and connections seem ok, but this board has a common rail for the +outs and the ground inputs.
Motors seem to work normally apart from this but I do have some fault on the limit stops which may be a crossed wire or dry joint.
Thanks John
Thanks John
- Thank you received: 7468
17 May 2021 22:05 #209283
Replied by tommylight on topic Stepper motors run free when enable is inactive
That should be as simple as inverting the pin that enables the drives, done in StepConf by clicking to the right of the said pin or editing the hal file.
Time to create page: 0.094 seconds
