Raspberry Pi 4 7i90 on Mojo V3 board
19 May 2021 22:28 #209560 by PCW
Replied by PCW on topic Raspberry Pi 4 7i90 on Mojo V3 board
I would tend to suspect a signal integrity issue
How long is your SPI cable and how many grounds are in the cable?
  • rbobey1989
  • rbobey1989's Avatar Topic Author
  • Premium Member
  • Premium Member
19 May 2021 22:45 - 19 May 2021 22:50 #209565 by rbobey1989
Replied by rbobey1989 on topic Raspberry Pi 4 7i90 on Mojo V3 board
I would not rule out the wiring, it could be, for now I am only using dupont cable, but they are only tests, also at 30khz I do not think that the integrity of the signal affects much, from my perspective, any solution for the wiring, I do not have grounds specifically in my connections, it is taken through the Raspberry usb to the Mojo V3 board
Last edit: 19 May 2021 22:50 by rbobey1989.
19 May 2021 22:50 - 19 May 2021 22:51 #209570 by PCW
The frequency is not really the important issue, the clock is still
a100 MHz capable high speed clock even if it only runs at 30 KHz
so any SI issues (ground integrity etc) can affect the data at 30 KHZ
or 30 MHz clock rates
Last edit: 19 May 2021 22:51 by PCW.
  • rbobey1989
  • Premium Member
  • Premium Member
19 May 2021 23:01 - 19 May 2021 23:13 #209575 by rbobey1989
Ok that I understand, but one controller yes and another no? mmmm gives food for thought. I could use other wiring and try
Last edit: 19 May 2021 23:13 by rbobey1989.
19 May 2021 23:22 #209581 by PCW
Yes SI issues may change with clock speed and other timing details.
not sure if hm2_spi and hm2_rpspi setup the hardware identically
so may behave differently if there are SI issues.
Note that even hm2_spi failed with what is most likely data corruption:
halcmd: loadrt hm2/hm2_7i90.0: pin 19 primary tag is 0 (end-of-list sentinel), expected 72 pins!
The following user(s) said Thank You: rbobey1989
  • rbobey1989
  • Premium Member
  • Premium Member
20 May 2021 00:26 #209586 by rbobey1989
amazing, i was blown away, thank you so much PCW you were absolutely right in the world, i added 3 ground wires and made a rough twisted pair, but it works like a charm.
halcmd: loadrt hostmot2
Note: Using POSIX realtime
halcmd: loadrt hm2_rpspi
hm2/hm2_7i90.0: Low Level init 0.15
hm2/hm2_7i90.0: 72 I/O Pins used:
hm2/hm2_7i90.0: IO Pin 000 (P1-01): IOPort
hm2/hm2_7i90.0: IO Pin 001 (P1-03): IOPort
hm2/hm2_7i90.0: IO Pin 002 (P1-05): IOPort
hm2/hm2_7i90.0: IO Pin 003 (P1-07): IOPort
hm2/hm2_7i90.0: IO Pin 004 (P1-09): IOPort
hm2/hm2_7i90.0: IO Pin 005 (P1-11): IOPort
hm2/hm2_7i90.0: IO Pin 006 (P1-13): IOPort
hm2/hm2_7i90.0: IO Pin 007 (P1-15): IOPort
hm2/hm2_7i90.0: IO Pin 008 (P1-17): IOPort
hm2/hm2_7i90.0: IO Pin 009 (P1-19): IOPort
hm2/hm2_7i90.0: IO Pin 010 (P1-21): IOPort
hm2/hm2_7i90.0: IO Pin 011 (P1-23): IOPort
hm2/hm2_7i90.0: IO Pin 012 (P1-25): IOPort
hm2/hm2_7i90.0: IO Pin 013 (P1-27): IOPort
hm2/hm2_7i90.0: IO Pin 014 (P1-29): IOPort
hm2/hm2_7i90.0: IO Pin 015 (P1-31): IOPort
hm2/hm2_7i90.0: IO Pin 016 (P1-33): IOPort
hm2/hm2_7i90.0: IO Pin 017 (P1-35): IOPort
hm2/hm2_7i90.0: IO Pin 018 (P1-37): IOPort
hm2/hm2_7i90.0: IO Pin 019 (P1-39): IOPort
hm2/hm2_7i90.0: IO Pin 020 (P1-41): IOPort
hm2/hm2_7i90.0: IO Pin 021 (P1-43): IOPort
hm2/hm2_7i90.0: IO Pin 022 (P1-45): IOPort
hm2/hm2_7i90.0: IO Pin 023 (P1-47): IOPort
hm2/hm2_7i90.0: IO Pin 024 (P2-01): IOPort
hm2/hm2_7i90.0: IO Pin 025 (P2-03): IOPort
hm2/hm2_7i90.0: IO Pin 026 (P2-05): IOPort
hm2/hm2_7i90.0: IO Pin 027 (P2-07): IOPort
hm2/hm2_7i90.0: IO Pin 028 (P2-09): IOPort
hm2/hm2_7i90.0: IO Pin 029 (P2-11): IOPort
hm2/hm2_7i90.0: IO Pin 030 (P2-13): IOPort
hm2/hm2_7i90.0: IO Pin 031 (P2-15): IOPort
hm2/hm2_7i90.0: IO Pin 032 (P2-17): IOPort
hm2/hm2_7i90.0: IO Pin 033 (P2-19): IOPort
hm2/hm2_7i90.0: IO Pin 034 (P2-21): IOPort
hm2/hm2_7i90.0: IO Pin 035 (P2-23): IOPort
hm2/hm2_7i90.0: IO Pin 036 (P2-25): IOPort
hm2/hm2_7i90.0: IO Pin 037 (P2-27): IOPort
hm2/hm2_7i90.0: IO Pin 038 (P2-29): IOPort
hm2/hm2_7i90.0: IO Pin 039 (P2-31): IOPort
hm2/hm2_7i90.0: IO Pin 040 (P2-33): IOPort
hm2/hm2_7i90.0: IO Pin 041 (P2-35): IOPort
hm2/hm2_7i90.0: IO Pin 042 (P2-37): IOPort
hm2/hm2_7i90.0: IO Pin 043 (P2-39): IOPort
hm2/hm2_7i90.0: IO Pin 044 (P2-41): IOPort
hm2/hm2_7i90.0: IO Pin 045 (P2-43): IOPort
hm2/hm2_7i90.0: IO Pin 046 (P2-45): IOPort
hm2/hm2_7i90.0: IO Pin 047 (P2-47): IOPort
hm2/hm2_7i90.0: IO Pin 048 (P3-01): IOPort
hm2/hm2_7i90.0: IO Pin 049 (P3-03): IOPort
hm2/hm2_7i90.0: IO Pin 050 (P3-05): IOPort
hm2/hm2_7i90.0: IO Pin 051 (P3-07): IOPort
hm2/hm2_7i90.0: IO Pin 052 (P3-09): IOPort
hm2/hm2_7i90.0: IO Pin 053 (P3-11): IOPort
hm2/hm2_7i90.0: IO Pin 054 (P3-13): IOPort
hm2/hm2_7i90.0: IO Pin 055 (P3-15): IOPort
hm2/hm2_7i90.0: IO Pin 056 (P3-17): IOPort
hm2/hm2_7i90.0: IO Pin 057 (P3-19): IOPort
hm2/hm2_7i90.0: IO Pin 058 (P3-21): IOPort
hm2/hm2_7i90.0: IO Pin 059 (P3-23): IOPort
hm2/hm2_7i90.0: IO Pin 060 (P3-25): IOPort
hm2/hm2_7i90.0: IO Pin 061 (P3-27): IOPort
hm2/hm2_7i90.0: IO Pin 062 (P3-29): IOPort
hm2/hm2_7i90.0: IO Pin 063 (P3-31): IOPort
hm2/hm2_7i90.0: IO Pin 064 (P3-33): IOPort
hm2/hm2_7i90.0: IO Pin 065 (P3-35): IOPort
hm2/hm2_7i90.0: IO Pin 066 (P3-37): IOPort
hm2/hm2_7i90.0: IO Pin 067 (P3-39): IOPort
hm2/hm2_7i90.0: IO Pin 068 (P3-41): IOPort
hm2/hm2_7i90.0: IO Pin 069 (P3-43): IOPort
hm2/hm2_7i90.0: IO Pin 070 (P3-45): IOPort
hm2/hm2_7i90.0: IO Pin 071 (P3-47): IOPort
hm2/hm2_7i90.0: registered
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
20 May 2021 01:44 #209595 by BeagleBrainz
Replied by BeagleBrainz on topic Raspberry Pi 4 7i90 on Mojo V3 board
Sweet this should be of interest to a few others.
I'm still amazed by the support provided by PCW on getting the Mesa firmware going on non-mesa hardware.
27 May 2021 06:57 #210427 by cakeslob
Replied by cakeslob on topic Raspberry Pi 4 7i90 on Mojo V3 board
github.com/sleepybishop/linuxcnc/tree/fishybearG-master
This guy has some cool stuff with the mojo, looks like hes using the onboard arduino as an adc for the temp reading on his 3dprinter, I copied his setup when I was playing with mine.
Its funny though, most fpga dev boards are priced higher than a mesacard. Aside from cheap chinese ones, the 7i90 is the one of the lowest price spartan6 based boards. even the mojo was like $70 on sparkfun
Time to create page: 0.136 seconds
