QTPlasmaC Stainless Steel
  • bevins
  • bevins's Avatar Topic Author
  • Platinum Member
  • Platinum Member
19 May 2021 00:20 #209428 by bevins
QTPlasmaC Stainless Steel was created by bevins
HTF you cut stainless 1/4"
I tried and tried. Ended up using 45 tip 40ipm and got it done but ugly cut.
1/8th no problem. Guess I should have used the 105 tip.
Hypertherm 105
  • Moderator
  • Moderator
19 May 2021 10:58 #209479 by tommylight
Replied by tommylight on topic QTPlasmaC Stainless Steel
Pretty much same as mild steel, but if possible use more current and more speed so the temperature affected area remains smaller.
Not sure what is going on, but use a tad bit more air pressure.
Stainless is very bad at conducting heat so it is somewhat easier to cut on a plasma, but i have limited experience with it like only 2mm thick.
Also check the slag under the cut, if it is easy to remove but there is a lot of it = moving to fast, if it is hard to remove = moving to slow.
  • bevins
  • Platinum Member
  • Platinum Member
19 May 2021 11:33 - 19 May 2021 11:39 #209485 by bevins
Replied by bevins on topic QTPlasmaC Stainless Steel
I got the job done but I have another question.
/EDIT I'll ask in a new thread.
Last edit: 19 May 2021 11:39 by bevins.
Time to create page: 0.174 seconds
