Control panel fans
- bevins
- Thank you received: 338
19 May 2021 11:41 #209486
by bevins
Control panel fans was created by bevins
Just wondering should fans be blowing in on the drives to keep them cool or suck air out? Seems to me blowing out but that wont kleep the drives cooler but blowing air across them would...... Is there a precedent or just need air flowing somehow?
- Thank you received: 4652
19 May 2021 12:32 #209495
Replied by andypugh on topic Control panel fans
Some discussion here: electronics.stackexchange.com/questions/6379/fans-suck-or-blow
One good point there is that with a blow-in fan you can filter the air before it enters the enclosure. With a suck-out fan you could filter the air as it leaves, but why would you?
- BeagleBrainz
- Visitor
19 May 2021 12:35 #209496
by BeagleBrainz
Replied by BeagleBrainz on topic Control panel fans
That's one thing I've been thinking about, at least in regards to the control cabinet.
Since hot air rises I was thinking that blowing cool air in low and sucking hot air out high may work. With the right filters to stop dragging swarf in.
- Thank you received: 4145
20 May 2021 07:57 #209621
Replied by rodw on topic Control panel fans
I suck air from the top right and have a vent inlet bottom left. You can put a filter on the inlet...
- aleksamc
- Thank you received: 67
20 May 2021 08:01 #209623
by aleksamc
Replied by aleksamc on topic Control panel fans
I've set many fans on cabinets and really neve ask myseld for such question.
Better is to cold blow air in the cabinet in down. All heat will move up and outside with extrapresure from the down fan.
Time to create page: 0.120 seconds
