axis job image and toolpath image
24 May 2021 04:09 #209993 by ericg
axis job image and toolpath image was created by ericg
Hi, I have a minor but annoying issue with my axis controller,, everything is working fine but when the job is running, the toolpath trace on the screen seems to be tracing roughly 1/4" (6mm) above the job image itself, no big deal but I would like to know why? is that normal or is there something I should alter?
cheers
Eric
  • Moderator
  • Moderator
24 May 2021 06:00 #210031 by tommylight
Replied by tommylight on topic axis job image and toolpath image
Active offsets or using probe on Z axis. Look at the center of the XYZ on screen, there should be a small green "globe" when offsets are active and in use. Use the mouse wheel to zoom in or the + on the tool bar above.
25 May 2021 11:33 #210215 by ericg
Replied by ericg on topic axis job image and toolpath image
Thanks, tommylight, I don't see any small green globes at the point where xyz are zeroed to the job, but some small circles at the home position, is that correct, I'm not sure I have a grasp on the coordinate system, reading up a bit now.
I did change the coordinates when I touched off from P0 (current) to P1 (G54) for each axis and the toolpath was right on the job image. more reading required I guess.
What I need is a dummies guide to it all, the documentation is getting harder for me to follow as I get older.
