Issues with new Build - Mesa 7i96 + DM542T
- Twitchy
24 May 2021 19:46 #210097
by Twitchy
Issues with new Build - Mesa 7i96 + DM542T was created by Twitchy
I am new to LInuxCNC. I am converting a mini-mill to CNC as a proof of concept with an eye toward building a CNC plasma table in the future. I am running LinuxCNC on an Odroid H+ with a 7i96 and 3 DM542T stepper drivers. Linux is installed, the 7i96 is talking to the OS and I am able to run PnCConf. When I run LinuxCNC, my end stops trigger appropriately and the ESTOP appears to function which suggests to me that I am at least on the right track with the 7i96 config. However, when I enable, I get no stepper motion when I manually jog. The steppers are holding. I know I must be missing something, but after combing though these forums, I am stuck.
I have attached my .hal and .ini. I am hoping you guys can steer me back on track.
- Online
- Thank you received: 5321
24 May 2021 20:43 #210099
Replied by PCW on topic Issues with new Build - Mesa 7i96 + DM542T
How are the drives wired to the 7I96s step/dir pins?
- Twitchy
24 May 2021 21:01 #210103
by Twitchy
Replied by Twitchy on topic Issues with new Build - Mesa 7i96 + DM542T
7i96 Step + > DM542T Step +
7i96 Step - > DM542T Step -
7i96 Dir + > DM542T Dir +
7i96 Dir - > DM542T Dir -
- Online
24 May 2021 21:04 #210105
I would try single ended connections
7i96 +5 > DM542T Step +
7i96 +5 > DM542T Dir +
7i96 Dir- > DM542T Dir -
And invert the step polarity in hal
- Twitchy
25 May 2021 02:37 #210175
by Twitchy
Thanks much. This set me on the path. This plus other excellent posts got me making chips. I have a ton to learn, but the machine is running.
Time to create page: 0.269 seconds
