Strange stepper issue at startup
27 May 2021 13:09 #210441 by Gregor96
Strange stepper issue at startup was created by Gregor96
I'm new to the forum so excuse me for any mistakes
I have a very strange issue with parallel BOB and DM542 driver. Sometimes at startup the steppers spin in the wrong direction, the moving some other axis and in the direction is travelling when wrong solves the issue, then once solved it doesn't have any issues when running, it might happen that the issue comes back even by only glossing and opening LinuxCNC again. I'm running the latest version.
Thanks for the support Gregor
27 May 2021 13:28 #210442 by PCW
Replied by PCW on topic Strange stepper issue at startup
I would check the BOB direction output voltage
when moving both directions it may be marginal.
Also check the BOB 5V supply voltage.
Time to create page: 0.073 seconds
