Newbie 6i25 + 7i76
28 May 2021 14:20 - 28 May 2021 16:18 #210526 by anrstone
Newbie 6i25 + 7i76 was created by anrstone
I have built my own CNC and I'm using the 6i25 (PCIe) card connected to a single 7i76. I have not changed the 6i25 from the default config it came with so I'm assuming the configuration should be the same as the 5i25. I initially configured the machine to run and set everything up and it worked but I noticed a few wiring faults and the like as well as I realised I hadn't tuned the stepper driver parameters.
When I went back into pncconf I inadvertently wiped the original config so started from scratch again. When I originally ran the pncconf I was certain that the board option was a 5i25. But that didn't seem to be in the options so I selected the 5i25 Internal Data + one 7i76. But when I went to the IO section the step generators seemed to be defined on the wrong 7i76 connector (P3 in the IO3 tab in the config) when they're presented on TB2. Clearly I have done something differently and the resulting configuration doesn't drive the steppers any more. Any idea what I might be doing wrong? Does P3 refer to the IO connector on the 6i25 board in which case I guess that makes sense and I guess I have mis-remembered what I did the first time... but I still can't quite see why it doesn't work.
Thanks and I hope that all makes some sense
Nick
Last edit: 28 May 2021 16:18 by anrstone.
30 May 2021 16:49 #210691 by andypugh
Replied by andypugh on topic Newbie 6i25 + 7i76
Yes, P3 is the DB25 connnector on the card, and P2 is the expansion connector.
www.mesanet.com/pdf/parallel/6i25man.pdf
02 Jun 2021 10:59 #210986 by anrstone
Replied by anrstone on topic Newbie 6i25 + 7i76
Thanks - I worked out my error. The clue was I fixed the wiring errors in the machine and it stopped working. The M542T stepper drivers have an "enable" which would better have been labelled "disable" as that's what they actually do :-)
Machine is running now and homing properly. Issue I have now is that I can't get micro-stepping to work for some reason but I'm guessing that's more hardware debugging...
Time to create page: 0.132 seconds
