limited motion when testing in Stepconf Wizard
- jruffsr
01 Jun 2021 21:27 #210916
by jruffsr
limited motion when testing in Stepconf Wizard was created by jruffsr
I had to replace my PC for my Light Machines CNC. I am using the same PCI parallel port card.
Here are what is listed when I checked parallel port information.
jruff@jruff-HP-ProDesk-600-G1-SFF:~$ cat /proc/ioports | grep parport
0000-0000 : parport0
jruff@jruff-HP-ProDesk-600-G1-SFF:~$ lspci -vv
02:00.0 Parallel controller: Oxford Semiconductor Ltd Device c110 (prog-if 02 [ECP])
Subsystem: Oxford Semiconductor Ltd Device c110
Control: I/O+ Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 16
Region 0: I/O ports at e010
Region 1: I/O ports at e000
Capabilities: <access denied>
Kernel driver in use: parport_pc
I have set the port ti 0xe010 and receive no error on startup of LinuxCNC. But I am unable to get any motion in JOG.
When I run Stepconf Wizard and test the X,Y,Z axis, I can see the motor make one "step" It moves the same direction Whether I click on < or >.
Please advise how to determine what could be causing this.
Thanls
Thanls
- BigJohnT
- Thank you received: 994
01 Jun 2021 21:52 #210921
by BigJohnT
Replied by BigJohnT on topic limited motion when testing in Stepconf Wizard
Often this is because step and direction pins are reversed.The direction pin will send only one pulse each time it changes direction.
JT
JT
- jruffsr
02 Jun 2021 14:21 #210998
by jruffsr
Replied by jruffsr on topic limited motion when testing in Stepconf Wizard
is there a document that details these pin outs? is it correct, I would need to update the pinouts in Stepconf Wizard?
Thank you for the quick response
- BigJohnT
02 Jun 2021 22:46 #211035
by BigJohnT
The Stepconf Tool will show what pin is used for each step and direction. You can search online for a parallel port pin location to verify you have the hardware connected to the correct pin.
linuxcnc.org/docs/2.8/html/hal/parallel-port.html
JT
JT
Time to create page: 0.319 seconds
