Is is prempt or preempt ??
- davef
03 Jun 2021 22:33 #211103
by davef
Is is prempt or preempt ?? was created by davef
My first post here...
I have Mint 19.3 running in a VM VirtualBox on Windows 10 Pro. I am following instructions to get stretch 2.7 preempt as detailed on buildbot.linuxcnc.org/
The Buildbot Packages List chart near the bottom shows to use this for my situation:
2.7 branch (stable)
Stretch (arch: amd64, i386)
uspace: realtime with RT-Preempt, and simulation
deb buildbot.linuxcnc.org/ stretch 2.7-rtpreempt
deb-src buildbot.linuxcnc.org/ stretch 2.7-rtpreempt
Note the (I believe) correct spelling of rtprEEmpt, not rtprEmpt. However,
when I set the needed repositories,
and did sudo apt update, I got these two error? / warning messages:
W: Skipping acquire of configured file '2.7-rtprempt/binary-i386/Packages' as repository 'buildbot.linuxcnc.org stretch InRelease' does not seem to provide it (sources.list entry misspelt?)
W: Skipping acquire of configured file '2.7-rtprempt/binary-amd64/Packages' as repository 'buildbot.linuxcnc.org stretch InRelease' does not seem to provide it (sources.list entry misspelt?)
Note the misspelling of rtprempt, (and ironically, misspelt is also misspelled.
When I searched the forum for prempt and preempt, I found it most-often "misspelt" as prempt,
Which is it, and what can I do, if anything, to correct the failure to acquire the amd64 package? (Or does it even exist at all, regardless of how it's spelled?)
I'm a bit of a NOOB, but I was able to install the 2.7 stretch 64 bit on Ubuntu 20.04.1 in a VM after much folderal, mostly because of missing dependencies (Python 2.? in particular, (which I found a repository for on the net and added that. So I don't think I really need to worry about this warning anyway, but thought I'd ask re the spelling error. I imagine I'm not the first to run into this.
TIA for any help.
2.7 branch (stable)
TIA for any help.
- Thank you received: 7468
03 Jun 2021 23:02 #211108
Replied by tommylight on topic Is is prempt or preempt ??
Why 2.7 ?
This always works for Mint:
forum.linuxcnc.org/9-installing-linuxcnc...nd-easy-installation
- davef
03 Jun 2021 23:50 - 03 Jun 2021 23:52 #211112
by davef
Replied by davef on topic Is is prempt or preempt ??
Thanks tommylight,
I actually used your excellent instructions in that post to get a successful install of linuxcnc on Ubuntu20.04.1 in a VM on my windows 10 OS. I'm so appreciative for all the work you did to help us all. I had to add a repository to get some of the python stuff (python-gst-1.0) I found this web page that helped with that: packages.ubuntu.com/bionic-updates/amd64...hon-gst-1.0/download
In Synaptic / Add Repositories, I added:
URL: mirrors.kernel.org/ubuntu
Dist: bionic-updates
Components: bionic-updates main universe
And... Bob's your Uncle!
Thanks again - Without your post I would have given up after days of trying to wrap my head around this stuff.
Last edit: 03 Jun 2021 23:52 by davef.
- davef
04 Jun 2021 00:40 #211115
by davef
Tommylight, To answer your question, "Why 2.7?" - The buildbot page says 2.7 is the stable release, and 2.8 is listed as (next release, being stabilized). So that's why I was going for that one. But I will do as you suggest, and use the 2.8 link in your post. Thanks.
- BeagleBrainz
- Visitor
04 Jun 2021 01:54 #211119
by BeagleBrainz
Replied by BeagleBrainz on topic Is is prempt or preempt ??
04 Jun 2021 11:24 #211143
The stable is 2.8.1 as Beagle pointed out.
Can you please post a link to that page so we can remove it?Tommylight, To answer your question, "Why 2.7?" - The buildbot page says 2.7 is the stable release, and 2.8 is listed as (next release, being stabilized). So that's why I was going for that one. But I will do as you suggest, and use the 2.8 link in your post. Thanks.
- phillc54
- Thank you received: 2100
04 Jun 2021 12:10 #211150
by phillc54
Replied by phillc54 on topic Is is prempt or preempt ??
Unfortunately the Buildbot page is a version behind. I did post an update after 2.8 was released but it didn't get incorporated...
- davef
05 Jun 2021 15:06 #211220
by davef
Tommylight,
I think maybe both of these pages need to be updated.
www.linuxcnc.org/downloads/
05 Jun 2021 15:54 #211227
The first link needs updating, the second i could not find why?
What did i miss ?
What did i miss ?
- Thank you received: 4652
08 Jun 2021 22:03 #211552
Replied by andypugh on topic Is is prempt or preempt ??
Unfortunately I think that only Seb has the keys for the buildbot page.
Time to create page: 0.135 seconds
