missing libgtk-3-0 package
05 Jun 2021 22:47 #211257 by szatri
missing libgtk-3-0 package was created by szatri
Hello, I am installing mpg xhc-whb04b-6 on debian 7 wheezy and I have a problem with the package:
checking for glib... yes - 2.32.4
checking for GTK 3.22.4 or above... no
configure: error: GTK3 missing.  Install with "sudo apt install libgtk-3-dev" or specify --disable-gtk to skip the parts of LinuxCNC that depend on GTK
nc @ debian: ~ / linuxcnc-dev / src $ sudo apt-get install libgtk-3-dev Reading package lists ... Done Building a dependency tree Reading status information ... Done libgtk-3-dev is now in the latest version. The following package was installed automatically and is no longer required: xaw3dg To remove it, use "apt-get autorove". 0 upgraded, 0 newly installed, 0 removed and 348 not updated.
it is not present in my repositories in version 3.22.4
# deb http://http.debian.net/debian wheezy main contrib non-free
# deb-src http://http.debian.net/debian wheezy main contrib non-free
# deb http://http.debian.net/debian wheezy-updates main contrib non-free
# deb-src http://http.debian.net/debian wheezy-updates main contrib non-free
deb http://security.debian.org/ wheezy/updates main contrib non-free
deb-src http://security.debian.org/ wheezy/updates main contrib non-free
deb http://http.us.debian.org/debian/ wheezy non-free contrib main
deb http://archive.debian.org/debian wheezy main contrib non-free
deb-src http://archive.debian.org/debian wheezy main contrib non-free
deb http://archive.debian.org/debian-security wheezy/updates main contrib non-free
deb-src http://archive.debian.org/debian-security wheezy/updates main contrib non-free
I downloaded a deb package but I can not install
debian.pkgs.org/9/debian-main-amd64/libg....11-1_amd64.deb.html
packages.debian.org/pl/source/sid/gtk+3.0
I downloaded the tar from here and unpacked it, I don't know what to do with it
download.gnome.org/sources/gtk+/
PS:
I will add that how to add repositories from debian stretch (there is in the required version), after downloading and updating the system has not started anymore
06 Jun 2021 23:07 #211383 by andypugh
Replied by andypugh on topic missing libgtk-3-0 package
Which LinuxCNC version are you trying to compile? LinuxCNC "master" no longer supports Wheezy. (partly because Wheezy went out of support 5 _years_ ago)
07 Jun 2021 14:53 #211422 by szatri
Replied by szatri on topic missing libgtk-3-0 package
hi, i use wheezy because it works stably with my lpt port (the port is integrated with the motherboard), apparently newer ones don't work like that with lpt pott. I tried with Xbuntu 18.04, the latency test is around 60,000, apparently on the verge of efficient operation (even when I run the test, the computer is terribly busy with this real-time kernel.) (In the case of whrezzy it worked normally)
I use this instruction to install mpg:
translate.google.com/translate?sl=pl&tl=...stemie-debian-7.html
I have a problem with the command:
sudo ./configure
reply:
checking for glib ... yes - 2.32.4
checking for GTK 3.22.4 or above ... no
07 Jun 2021 20:13 #211444 by szatri
What repositories do you have for wheezy?
10 Jun 2021 13:47 #211698 by andypugh
You should be able to compile and run LinuxCNC 2.8 on Wheezy. This is the current released version.
If you have a git clone, then just "git checkout 2.8" and it should build on Wheezy.
Or, you can get a pre-built .deb file image from buildbot.linuxcnc.org
15 Jun 2021 11:08 #212111 by szatri
i use Lcnc version 2.9 pre but it doesn't matter anymore.
Only installing debian 9 or debian10 solves this problem with the wrong file version.
Time to create page: 0.692 seconds
