Manual machine + scales + mesa card + linuxcnc = DRO?
  • NewGuyJim
  • NewGuyJim's Avatar Topic Author
  • New Member
  • New Member
12 Jun 2021 04:11 #211853 by NewGuyJim
Is there any reason LinuxCNC won't give at least position indication, given input from suitable scales? My intention is full-on CNC conversion but manual work will enable that, and that leads me to my question.
Jim
12 Jun 2021 09:54 #211860 by pippin88
I don't understand the question.
Do you mean can you use LinuxCNC as a DRO (with no output / motor function)?
Yes.
14 Jun 2021 22:23 #212064 by andypugh
You need to set the GUI to showfeedback rather than commanded position, but as long as you do that, it will work as a DRO.
(And it would be very easy to make a DRO-only config if you wanted, DRO is a single GladeVCP widget.)
Time to create page: 0.177 seconds
