Probe Screen Really Slow
19 Jun 2021 16:09 - 19 Jun 2021 16:44 #212418 by rajewski
Probe Screen Really Slow was created by rajewski
I'm still in the "setup everything" phase and just added the probe screen (github.com/linuxcnc-probe-screen/probe-screen-ng) to my install.
It all seems to be working, but there are huge delays (5+ seconds) between most move when probing. I *think* the delays may be between subroutine calls in the macros but I'm not 100% sure of that.
When doing a simple Z height probe, after clicking the icon it doesn't do anything for 4 seconds, does the whole probe routine as expected, then sits around for 6 seconds before showing the result. The more complex probes (corners, etc) are worse and pause between each movement.
I had written my own basic probing macros before discovering the probe screen and my macros run quickly as expected.
Is this something inherent with how it works (python?) or is something wrong with my setup?
For what it's worth, I'm using GMOCCAPY 3.0.9.1 and Linuxcnc 2.8.1
Thanks,
Justin
Last edit: 19 Jun 2021 16:44 by rajewski.
19 Jun 2021 17:42 #212430 by Mr. Mass
Replied by Mr. Mass on topic Probe Screen Really Slow
I had the same issue. NG probe worked perfectly with axis and very slow with gmoccapy. I spent many time to trying to force to work probe screen with gmocappy interface. In my case decision was this variation of probe screen - github.com/GuiHue/probe_screen_v2
This screen have issues too, not work manual movement and after any action with probe always moves to mdi section. But rest of it work fine and fast with gmoccapy.
20 Jun 2021 19:51 #212509 by rajewski
Replied by rajewski on topic Probe Screen Really Slow
I found the bug. After messing around with GladeVCP and python I realized any delays were definitely from their code and not inherent with LinuxCNC.
On line 135 in base.py, they had time.sleep(ms / 100) which should've been time.sleep(ms / 1000)
This was making every check for errors on GMOCCAPY take 10x as long as they should (3 seconds instead of 0.3)
The following user(s) said Thank You: HalaszAttila
21 Jun 2021 23:20 #212610 by andypugh
Replied by andypugh on topic Probe Screen Really Slow
I see that alkabal has raised a pull-request to fix this.
22 Jun 2021 06:03 #212641 by alkabal
Replied by alkabal on topic Probe Screen Really Slow
Hello
Yes but i suspect that kiall is no more active and i don't have the write access...
I have my own fork that use different macro logic but python code is really similar.
24 Jun 2021 01:20 - 24 Jun 2021 01:26 #212777 by rajewski
I also found through more testing it needs to be 1000.0 not 1000 or it is doing integer math and rounds down to 0.
Edit: Apparently in Python an int/int becomes a float so I'm not sure why it wasn't working with 1000 but is working with 1000.0 for me.
Last edit: 24 Jun 2021 01:26 by rajewski.
The following user(s) said Thank You: HalaszAttila, Ralfh
Time to create page: 0.422 seconds
