PostProcessor linuxcnc
- Michael_k
21 Jun 2021 08:39 #212543
by Michael_k
PostProcessor linuxcnc was created by Michael_k
Hello, I‘m a mechinical student from Germany. I‘m working on a PostProcessor for a linuxcnc based system. The idea is to find a PP that’s works well with linuxcnc and i only have to do minor changes in Programm code, instead of building one from scratch.
I read the FANUC PP works fine with linuxcnc.
Do you have any other suggestions?
Thanks in advance
Thanks in advance
- 0x2102
- Thank you received: 88
21 Jun 2021 18:26 #212576
by 0x2102
Replied by 0x2102 on topic PostProcessor linuxcnc
Hello Michael,
the question is for which CAM system?
- Thank you received: 4652
22 Jun 2021 00:16 #212625
Replied by andypugh on topic PostProcessor linuxcnc
And what language is the PP written in?
The Fusion360 LinuxCNC PP works pretty well. That seems to be written in Javascript
- Michael_k
22 Jun 2021 06:23 #212644
by Michael_k
Replied by Michael_k on topic PostProcessor linuxcnc
Hello,
I’m using SolidCAM
I’m using SolidCAM
- Michael_k
22 Jun 2021 07:33 #212650
by Michael_k
I’m working in SolidCAM an need to find a PP for it
23 Jun 2021 13:13 #212737
Fanuc or Mach3 will be close to LinuxCNC.
Is there one called "EMC2"? That was the old name for LinuxCNC and some CAM systems still use that to refer to LinuxCNC.
Time to create page: 0.153 seconds
