Understaning PWM
5 years 3 months ago #214189 by PCW
Replied by PCW on topic Understaning PWM
You also need to get the polarities of the PWM and enables signal going to the SPINx1 correct
5 years 3 months ago #214197 by hairyMug
Replied by hairyMug on topic Understaning PWM
definitely the spinx as the signal from the 7i96 looks good...
I switched the "wiper" and "ref" but it only knocked the rpms to 6800...
Going to try flipping the PWM and see if that helps... but at least I see light at the end of a long tunnel..
5 years 3 months ago #214206 by hairyMug
No matter what I do, it refuses to work and, using the docs for PWMGEN, there are parameters that are not there in this PWMGEN object...
I've switched all I can possibly switch wire-wise... I GIVE UP!
Being a glutton for punishment, (and I have to get my spindle controlled), my VFD supports a rs485 interface so I'm going to look at that as an alternate method of spindle control...
I am hoping to find some info on the rs485 interface of the 7i96...
5 years 3 months ago #214214 by PCW
Did you verify:
1. +5V to +15V on SPINX1 SP+ relative to SPINX1 SP-
2. SPV = 0V when unconnected to 7I96
3. SPINX1 PWM connected to 7I96 TB2 pin 3 (PWM+)
4. SPINX1 DIR connected to 7I96 TB2 pin 5 (DIR+)
5. SPINX1 /ENA driven by a SSR output (OUT+ to SPINX1 /ENA
OUT- to GND)
5 years 3 months ago #214386 by andypugh
Replied by andypugh on topic Understaning PWM
You are maybe looking at the wrong pwmgen.
For the Mesa cards, the pwmgen is (badly) documented here:
linuxcnc.org/docs/2.8/html/man/man9/hostmot2.9.html#pwmgen
The software pwmgen is here (you probably don't want to use this one, it's largely for the parallel port)
linuxcnc.org/docs/2.8/html/man/man9/pwmgen.9.html
And, for completeness:
linuxcnc.org/docs/2.8/html/drivers/pico-ppmc.html
5 years 3 months ago #214410 by hairyMug
all voltages spec'ed by PCW are as stated...
Thanks for the alternate doc link Andy...
I have a feeling the PWM (as well as DIR) polarity need to be reversed as when I start, the VFD shows REV rotation...
>> It's a cross between and elephant and a rhino... Ele-if-I-no...
Time to create page: 0.384 seconds
