Understaning PWM
5 years 3 months ago #214424 by hairyMug
Replied by hairyMug on topic Understaning PWM
ok; It turns out the enable signal needs to be inverted.
So, I went to pncconfig tool and said to invert the output...
It generated:
setp hm2_7i96.0.ssr.00.out-00.invert_output true
Which promptly created a startup error... Silly me, I thought something this easy would work...
5 years 3 months ago - 5 years 3 months ago #214425 by PCW
Replied by PCW on topic Understaning PWM
Umm, no
The SPINX1 enable signal is active low so you wire
OUT0- to GND and OUT0+ to the SPINX1's /ENABLE signal,
so when SSR 0 is on (true in hal) , the SPINX1 /ENABLE
signal is low and the SPINX1 is enabled.
Last edit: 5 years 3 months ago by PCW.
5 years 3 months ago - 5 years 3 months ago #214438 by hairyMug
this does not sound right...
First of all, I see no capability in the pncconfig tool for specifying a + & - for an output...
Is this available as a HAL command?
Also, why would the + be connected to the SPINX enable? if it should be LOW to enable?
...I'm just not getting it...
the light just came on...image missing /media/kunena/emoticons/smile.png sso connects the enable to ground...
Last edit: 5 years 3 months ago by hairyMug.
5 years 3 months ago #214442 by PCW
Yes, its just a switch
( A polarized switch so the most positive signal must connect to OUTN+ )
5 years 3 months ago #214457 by hairyMug
ok... still have the issue of no speed control; it's off or full speed, 24000 rpm...
and I did a dump of the pin-outs and the two pins are :
pin 25:
Primary Tag: 0x03 (IOPort)
Secondary Pin: 0x81 (PWM, Output)
pin 26:
Secondary Pin: 0x82 (Dir, Output)
I would not expect them to be one after another? since they are supposed to be step+ and dir+
Something does not add up
5 years 3 months ago - 5 years 3 months ago #214472 by PCW
They are sequential
Is the PWM scale set to 24000?
PWM is active high. If you have the SPINX1 PWM signal connected to TB2 pin3 (STEP4+) , PWM should be 0 when the commanded spindle speed is 0. You should verify this with a voltmeter.  (the voltmeter will read the average so should read
0V on STEP4+  at 0 PWM, about 2.5V at 50% PWM and about 5V at100% PWM.
The SPV voltage relative to SP- should track these voltages (scaled up by the 10V or so between SP+ and SP-)
Time to create page: 0.065 seconds
