Understaning PWM
- hairyMug
- Thank you received: 3
12 Jul 2021 22:28 - 12 Jul 2021 22:37 #214438
by hairyMug
Replied by hairyMug on topic Understaning PWM
this does not sound right...
First of all, I see no capability in the pncconfig tool for specifying a + & - for an output...
Is this available as a HAL command?
Also, why would the + be connected to the SPINX enable? if it should be LOW to enable?
...I'm just not getting it...
the light just came on... sso connects the enable to ground...
Last edit: 12 Jul 2021 22:37 by hairyMug.
- Thank you received: 5326
12 Jul 2021 22:44 #214442
Replied by PCW on topic Understaning PWM
Yes, its just a switch
( A polarized switch so the most positive signal must connect to OUTN+ )
- hairyMug
13 Jul 2021 00:02 #214457
by hairyMug
ok... still have the issue of no speed control; it's off or full speed, 24000 rpm...
and I did a dump of the pin-outs and the two pins are :
pin 25:
Primary Tag: 0x03 (IOPort)
Secondary Pin: 0x81 (PWM, Output)
pin 26:
Secondary Pin: 0x82 (Dir, Output)
I would not expect them to be one after another? since they are supposed to be step+ and dir+
Something does not add up
pin 25:
pin 26:
13 Jul 2021 02:15 - 13 Jul 2021 02:20 #214472
They are sequential
Is the PWM scale set to 24000?
PWM is active high. If you have the SPINX1 PWM signal connected to TB2 pin3 (STEP4+) , PWM should be 0 when the commanded spindle speed is 0. You should verify this with a voltmeter. (the voltmeter will read the average so should read
0V on STEP4+ at 0 PWM, about 2.5V at 50% PWM and about 5V at100% PWM.
The SPV voltage relative to SP- should track these voltages (scaled up by the 10V or so between SP+ and SP-)
Last edit: 13 Jul 2021 02:20 by PCW.
- hairyMug
13 Jul 2021 10:09 #214526
by hairyMug
Mystery Solved!
Thank you SO MUCH!
I looked at the pins and realized I was using Stepper#3... DUH
Now that I use #4, I just need to tweak the scale and it should be good to go.
What a "learning experience"
Thank you SO MUCH!
13 Jul 2021 16:49 #214616
Replied by andypugh on topic Understaning PWM
You learned that geeks have nine fingers: finger zero, finger one....What a "learning experience"
- hairyMug
13 Jul 2021 17:53 #214629
by hairyMug
I R A GEEK! (from the Windows world)
>> this HAL programming SCREAMS for a pre-compiler to translate "normal" programming to "HAL-speak"...
It's almost like going back to C++ from C#!
In any case, I will post a topic with my files to maybe help another poor soul...
Thanks All for your help!
Time to create page: 1.349 seconds
