hy_vfd ttyUSB0 disconnects & reconnects as ttyUSB1
30 Jun 2021 18:51 #213356 by NB70
I'm trying to use the hy_vfd component to control my Huanyang  VFD using a waveshare usb-to-RS485  device.
I can connect to the VFD, start it and set it to the right speed (e.g. using halcmd & in AXIS GUI)  but then ttyUSB0 disconnects and I lose control over it. When I check the /dev/ folder ttyUSB0 is gone and now the usb-to-RS485 device is at ttyUSB1.
I've tried making a udev rule so that "ttyUSB_RS485" always links to the usb-to-RS485 device
SUBSYSTEM=="tty", ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6001", ATTRS{serial}=="AB0JO0HA",  SYMLINK+="ttyUSB_RS485"
It connects correctly at program start up but it does not solve the problem as the ttyUSB still disconnects mid-program.
I've tried a different USB-to-RS485 a dapter but had the same problem.
30 Jun 2021 19:44 #213360 by NB70
Some more information.
This is the sequence of halrun commands I used:
halrun
loadusr -Wn vfd hy_vfd -n vfd -d /dev/ttyUSB_RS485 -p none -r 9600
setp vfd.enable 1
setp vfd.speed-command 6000
setp vfd.spindle-forward 1
setp vfd.spindle-on 1
The spindle then starts and accelerates to 6000 - but then I get the following error message
ERROR Write port/socket failure (-1)
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
30 Jun 2021 21:32 #213379 by BeagleBrainz
Replied by BeagleBrainz on topic hy_vfd ttyUSB0 disconnects & reconnects as ttyUSB1
Have you checked dmesg to see what is causing the disconnects ?
Have you tried other USB ports on your machine ?
Does this happen outside of the Linuxcnc environment?
Eg if you tried to do a loop back test using a serial terminal program ?
It does sound like a frustrating issue.
30 Jun 2021 21:49 #213384 by PCW
It sounds like it may be a EMI issue
I would try adding a common mode choke (giant ferrite bead)
around the RS-485 cable near the USB converter to avoid
stray HF ground currents in the USB cable.
01 Jul 2021 08:50 #213420 by NB70
Thanks both - I've ordered a ferrite bead & I'll also try the troubleshooting suggested by BeagleBrainz .
06 Jul 2021 18:15 #213878 by NB70
This problem is now fixed - it was an EMI issue as PCW suggested.
I checked dmesg - a couple of lines pointed to the EMI issue:
[  395.170184] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - nonzero urb status: -71
[  395.232153] usb usb5-port1: disabled by hub (EMI?), re-enabling...
Also the fact that the connection dropped when the VFD (& its electrical noise) starts up is another clue
I tried adding a clip-on ferrite bead - but this did not solve the problem.
The main culprit I'm sure was the cable - I was using an unshielded twisted pair cat5 cable. I changed this for a shielded cat7 (plus the ferrite bead) and connected the shield to the ground terminal on the waveshare USB-RS485 convertor.
Thanks again for the help!
Time to create page: 0.149 seconds
