Jetson Nano as LinuxCNC driver 2021
- Matt Hat
03 Jul 2021 21:40 - 03 Jul 2021 22:20 #213592
by Matt Hat
Jetson Nano as LinuxCNC driver 2021 was created by Matt Hat
Hi everyone,
I am eager to setup LinuxCNC on Jetson Nano. Has there been progress since the initiatives in 19/20 by DougM, tommylight, tim292stro, hobbyno1, and others? Link to 2019-2020 posts
Could anyone potentially provide a compiled, tested, and running kernel/environment for a linux newbe like me?
Anything simpler than going through Instructions by ajcalderont and troubleshoot any upcoming issues? Link to ajcalderont's instructions
System specs: Tegra X1 (nvgpu)/integrated, 64bit, 3.9GiB memory, ARMv8 rev 1 (v8l) x 4
R32, Rev. 5.1, GCID: 26202423, BOARD: t210ref, EABI: aarch64, Feb 19
L4T core: arm 64-bit, Version 32.5.1-20210219084526
Ubunto 18.04 LTS installed
Last edit: 03 Jul 2021 22:20 by Matt Hat. Reason: adding links to previous posts
- Thank you received: 7468
03 Jul 2021 22:22 #213603
Replied by tommylight on topic Jetson Nano as LinuxCNC driver 2021
Never got one.
- Matt Hat
04 Jul 2021 06:38 #213646
by Matt Hat
Replied by Matt Hat on topic Jetson Nano as LinuxCNC driver 2021
Never got a jetson board or a solution to run linuxCNC on it?
04 Jul 2021 10:41 #213656
Board.
- Matt Hat
24 Dec 2021 23:52 #229937
by Matt Hat
I changed my plans and simply run GRBL on Arduinos and/or use linuxcnc on some intel Desktops from the 90s. Both options work well for me.
Time to create page: 0.146 seconds
