multi axis synchronous jog?
- atrex77
- Thank you received: 24
11 Jul 2021 19:42 #214311
by atrex77
multi axis synchronous jog? was created by atrex77
Hi all,
please help me, i want to make cnc spinning machine with linuxcnc, my python code to track the contours is nearly finished but i need to
jog axes in synchronous and i dont know can i make.
- Thank you received: 2164
11 Jul 2021 19:57 #214313
Replied by Aciera on topic multi axis synchronous jog?
Could you explain more what you mean with "synchronous jog"?
- atrex77
11 Jul 2021 20:02 - 11 Jul 2021 20:07 #214314
by atrex77
Replied by atrex77 on topic multi axis synchronous jog?
start 2 axis jog in realtime, when you call command.jog() in two axes not start same time.
like this:comm.jog(linuxcnc.JOG_CONTINUOUS, False, 0, xv * jfeed)
comm.jog(linuxcnc.JOG_CONTINUOUS, False, 2, zv * jfeed)
Last edit: 11 Jul 2021 20:07 by atrex77.
- Grotius
- Thank you received: 2349
11 Jul 2021 22:29 #214333
by Grotius
Replied by Grotius on topic multi axis synchronous jog?
I don't understand your problem but it looks like one axis is starting sooner then the second axis in time.
Your python command's are done from a gui updating thread let's say 100ms interval. This is i think your problem.
If you want to have more freedom, try to use the stepgen component.
Then you can sent position value's with halcmd. Then in python you can code the motion profile's for your spinning machine.
The following user(s) said Thank You: atrex77
- Thank you received: 4652
13 Jul 2021 00:12 #214459
This looks like Python code, so _isn't_ realtime.
Is there any way to move this to a realtime component, controlled by the Python code via HAL pins?
Replied by andypugh on topic multi axis synchronous jog?
- Thank you received: 2175
13 Jul 2021 05:16 #214483
Replied by cmorley on topic multi axis synchronous jog?
There is no way to actually synchronize jogs of multiple axes (currently anyways)
You could probably get something very close by starting two independent jogs in realtime (as Andy, I thinking is leading to)
I guess it depends on how synchronized you need.
it would be nice to have a true multi axes jog - for chamfering on a lathe for instance.
- atrex77
13 Jul 2021 05:16 - 13 Jul 2021 05:43 #214484
by atrex77
Good idea, but how to pass multiple values realtime to hal?
I explain the full problem, i need to teach the movements by hand with joystick and cannot cross the bounding curves and move seamlessly.
tried to switch between jog (free moves) and mdi(bounding curves) mode but not working because of lag in switching modes.
I switched to full jog mode teaching, but because of axes not start synchronized a small gap between the bounding curve and the moves.
Later I upload the code with instructions to use, but I need to go to working.
Last edit: 13 Jul 2021 05:43 by atrex77.
- atrex77
13 Jul 2021 21:03 #214644
by atrex77
ok i solve my sync jog problem.
i made a hal component that get input of an angle then make 2 analog out from it.
component syncjog;
pin in float angle;
pin out float analog0;
pin out float analog1;
function _;
license "GPL";
#include <rtapi_math.h>
const float k = 3.1415926535 / 180;
//main function
FUNCTION(_) {
analog0 = sin(angle * k);
analog1 = cos(angle * k);
component syncjog;
pin in float angle;
function _;
license "GPL";
//main function
FUNCTION(_) {
Time to create page: 0.157 seconds
