- LinuxCNC
- General LinuxCNC Questions
- How can i add the process when adding ethernet devices and serial devices?
- curran209
15 Jul 2021 03:15 #214804
by curran209
How can i add the process when adding ethernet devices and serial devices? was created by curran209
Is it need to go through IO moudule and HAL layer when add related devices?
- Thank you received: 7468
19 Jul 2021 00:11 #215272
Replied by tommylight on topic How can i add the process when adding ethernet devices and serial devices?
Sorry for the late reply,
A bit more info would help as i am not sure if you mean adding the ethernet or SSerial device or adding a process to what ?
Or do you mean adding a process for eth/SSerial to a running LinuxCNC instance ?
- curran209
19 Jul 2021 06:38 #215285
by curran209
Replied by curran209 on topic How can i add the process when adding ethernet devices and serial devices?
Our machine tool's controller is a Industrial Personal Computer, it connect a few devices, such as motors by Ethercat, Laser marking card by ethernet cable(there is none can support Ethercat ), Range controller(need both directly connect RS485 and connect Ethercat trans RS485). I want to control motors by Linuxcnc. Motors and Laser marking card controlled by same a G code file, so i need add the Ethernet(Laser marking card) control program in Linuxcnc, I got the API that control the the Laser marking card by its offical website. So i want to know whether i don't need modify linuxcnc HAL when i want to control a device directly connected by ethernet cable, whether my program doesn't go through HAL.
- Thank you received: 4652
29 Jul 2021 20:48 #216266
Replied by andypugh on topic How can i add the process when adding ethernet devices and serial devices?
The easiest way is probably to write a HAL driver using the API.
This _probably_ needs to be a user-space driver.
- LinuxCNC
