G33.1 Rigid Tapping
22 Jul 2021 06:40 #215549 by Michael_k
G33.1 Rigid Tapping was created by Michael_k
I’m using a ISEL1200-is Frequency Converter and trying to do Rigid tapping.
As i Programm G33.1 for syncing nothing happens.
Could there be some problem with the hardware?
I’m new to Linux CNC and CNC in general, if you need more info, feel free to ask.
Thank you
22 Jul 2021 10:38 #215559 by BigJohnT
Replied by BigJohnT on topic G33.1 Rigid Tapping
G33.1 is a spindle synchronized move which requires an encoder on the spindle.
linuxcnc.org/docs/2.8/html/gcode/g-code.html#gcode:g33.1
Spindle synchronized moves also require the spindle at speed pin to be on.
JT
The following user(s) said Thank You: Michael_k
Time to create page: 0.083 seconds
