[solved] HAL pin indicating state of G91/G90
  • Aciera
  • Aciera's Avatar Topic Author
  • Administrator
  • Administrator
23 Jul 2021 13:37 #215688 by Aciera
HAL pin indicating state of G91/G90 was created by Aciera
Does anybody know if there is a hal pin that indicates the state of G90/G91 mode?
I'd like to have the state indicated on my machine panel.
23 Jul 2021 13:57 #215691 by rodw
Replied by rodw on topic HAL pin indicating state of G91/G90
23 Jul 2021 18:24 #215709 by cmorley
Replied by cmorley on topic HAL pin indicating state of G91/G90
What version of linuxcnc are you using?
  • Aciera
  • Administrator
  • Administrator
24 Jul 2021 07:23 #215744 by Aciera
Replied by Aciera on topic HAL pin indicating state of G91/G90
I'm using current master.
  • Aciera
  • Administrator
  • Administrator
24 Jul 2021 07:54 - 24 Jul 2021 09:52 #215748 by Aciera
So my approach would be to create a python (or C) component to get the parameters mapped to hal-pins but I can't get my head around on how to access the paramters:
#<_absolute>
#<_incremental>
Does anybody have an example to get me started?
[edit]
I guess I could parse the contents of the linuxcnc.stat object?
linuxcnc.org/docs/html/config/python-interface.html
Or I think this is better:
linuxcnc.org/docs/html/gui/GStat.html
Ok this one doesn't seem to report back when G90/G91 changes.
[edit2]
I solved this by using linuxcnc.stat
Last edit: 24 Jul 2021 09:52 by Aciera.
24 Jul 2021 16:37 #215790 by cmorley
Replied by cmorley on topic [solved] HAL pin indicating state of G91/G90
I will add g90/91 to Gstat - for the future.
Time to create page: 0.352 seconds
