Artificial Neural Networks working with Hal
- Grotius
- Thank you received: 2349
23 Jul 2021 20:21 #215712
by Grotius
Artificial Neural Networks working with Hal was created by Grotius
I was curious how to use Artificial Networks. I found a nice blog how to do it.
This blog explain's a basic Xor logic example. ( 2 inputs, 1 output )
In linuxcnc the component xor2.comp is more or less the same.
I compiled the c++ example and it worked. Output is oke.
Now i am planning to test this Artificial Network working within a hal component.
If the program is trained, it can predict a solution.
What should be a nice thing to predict in linuxcnc hal?
- Thank you received: 2175
24 Jul 2021 03:45 #215735
Replied by cmorley on topic Artificial Neural Networks working with Hal
backlash compensation.
actually any compensation.
PID control?
PID control?
- robertspark
- Thank you received: 216
24 Jul 2021 07:44 #215747
by robertspark
Replied by robertspark on topic Artificial Neural Networks working with Hal
torch height (voltage)
torch void detection (voltage spike outside of standard deviation)
- Grotius
24 Jul 2021 11:00 #215760
by Grotius
Replied by Grotius on topic Artificial Neural Networks working with Hal
I just finished the hal implementation of the arteficial neural network performing a xor2 function.
The code is at github, you can look at it. It works ok with linuxcnc on the servo-thread.
First i train the ai providing the training_data file. # setp train 1
Then i run the ai with # setp run 1
Once the ai is trained. You don't have to train it again next time linuxcnc starts.
I think when to make any implementation request's succesful we have to consider the following:
- the ai has to be trained. User has to provide a training set.
The training set can be for example this file , where line 2,3 are a set. line 4,5 are a set, etc.
Line 2 = input 0,1 (xor2 input)
Line 3 = result input 0,1 (xor2 output)
and so on.
I see the request's are manly for position control purposes.
and so on.
- Thank you received: 7468
24 Jul 2021 13:55 #215778
Replied by tommylight on topic Artificial Neural Networks working with Hal
Sorting recycling with an efector and camera,
Sorting clothes for big retailers,
Quality control,
Quality control,
- robertspark
24 Jul 2021 23:19 #215815
by robertspark
I am confused.... I've read... I don't understand how it works (yet!)... off to read again....
- Grotius
25 Jul 2021 09:37 - 25 Jul 2021 09:45 #215845
by Grotius
The library that is used.
The library set's up the neural network, input's, output's, layers between etc.
In the example there are 2 input's and 1 output.
The ai is trained from a data sheet how the result on the output should be, when the 2 input's are at different states.
Normally we should code this in c or c++ by :
if(input0==0 && input1==0){output=1;}
if(input0==1 && input1==1){output=1;}
if(input0==0 && input1==1){output=0;}
if(input0==1 && input1==0){output=0;}
In the "ai network" we can train above situation by giving the desired output like :
input0=0 input1=0
-> ouput=1
input0=1 input1=1
-> ouput=1
input0=0 input1=1
-> ouput=0
input0=0 input1=1
-> ouput=0
Behind the screen the ai is trained. This example is trained within 1 second. But i have already experienced a training period
of around 1 minute for a more complex situation.
You can in fact cheet the output with an ai quite easy by giving wrong results in the training sheet. For example we now
have cheeted the ouput to a inverted xor2 output.
input0=0 input1=0
-> ouput=0
input0=1 input1=1
-> ouput=0
input0=0 input1=1
-> ouput=1
input0=1 input1=0
-> ouput=1
I hope this tiny example helps a bit.
input0=0 input1=0
-> ouput=1
input0=1 input1=1
-> ouput=1
input0=0 input1=1
-> ouput=0
input0=0 input1=1
-> ouput=0
input0=0 input1=0
-> ouput=0
input0=1 input1=1
-> ouput=0
input0=0 input1=1
-> ouput=1
input0=1 input1=0
-> ouput=1
Last edit: 25 Jul 2021 09:45 by Grotius.
The following user(s) said Thank You: HalaszAttila, robertspark
Time to create page: 0.237 seconds
