qtplasmac ext_height_ovr
  • billykid
  • billykid's Avatar Topic Author
  • Platinum Member
  • Platinum Member
25 Jul 2021 18:43 #215896 by billykid
qtplasmac ext_height_ovr was created by billykid
hi, I tried to configure a small panel encoder for arc correction and it works but only with scale 1. Do you need a higher resolution encoder or is there a different system?
26 Jul 2021 08:25 #215934 by fupeama
Replied by fupeama on topic qtplasmac ext_height_ovr
Hi. Its similar like a halui.feed-everride. Only connect encoder.counts to ext.....counts. both s32.  I dont need Scale, but you Are right It will be better with Scale. I will write It when I arrive from holiday. Martin
The following user(s) said Thank You: billykid
  • billykid
  • Platinum Member
  • Platinum Member
26 Jul 2021 10:12 - 26 Jul 2021 11:03 #215943 by billykid
Replied by billykid on topic qtplasmac ext_height_ovr
In fact, at the beginning I had used encoder counts s32 but since it moved 1 at a time I wanted to scale and I used encoder position, but from the float.s32 converter output I always have steps of 1 spaced from the scale.
Good holiday!
Mauro
Last edit: 26 Jul 2021 11:03 by billykid.
11 Aug 2021 12:21 #217531 by fupeama
Hi,I made your request and now I'm waiting for Phill to be so kind and commit my PR.
Martin
  • billykid
  • Platinum Member
  • Platinum Member
11 Aug 2021 16:48 #217560 by billykid
Something has already changed I know because now it is 0.5 - 1 -1.5 - 2 at 0.5 mm pitch
Time to create page: 0.228 seconds
