Config Files
27 Jul 2021 19:16 #216062 by imslo
Config Files was created by imslo
I just got a better computer and installed Buster on it.  I was running Stretch 2.9 .  I thought I could I rename the Linuxcnc folder and copy my Linuxcnc folder on the new install and it would be all setup.  It would not run at all with my files.  I did this on my last computer change with no problems.  Can this be done?
27 Jul 2021 22:07 #216073 by andypugh
Replied by andypugh on topic Config Files
I am not 100% clear on what it is you did exactly, but there shouldn't be any problems moving configs between 2.9 and 2.8.
What error report do you get?
28 Jul 2021 01:21 #216092 by imslo
Replied by imslo on topic Config Files
What I did was just replace the total linuccnc folder with the one from my old machine. I had a config file set up and tried to run from this file. I just got a page full of junk that said at the top something like "errors encountered". I was so tired of trying to set every thing up I just went back to my old machine. It runs cnc fine but is very slow for every thing else. i'll try again later. Thanls for the reply.
28 Jul 2021 08:15 - 28 Jul 2021 08:16 #216112 by Aciera
Replied by Aciera on topic Config Files
No, you don't want to do that.
You usually only need to copy your machine configuration folder (ie the one that contains your .hal and .ini files) into the 'linuxcnc/configs' folder of the new installation.
Last edit: 28 Jul 2021 08:16 by Aciera.
28 Jul 2021 17:17 #216137 by imslo
Thanks, I'll try that when i get the machine back out.
03 Aug 2021 21:13 #216865 by imslo
I copied the config folder and it is running slick as a button. Thanks for the advice.
Time to create page: 0.175 seconds
