How can i use the function of linuxcnc by a custom remote windows UI?
29 Jul 2021 08:19 #216198 by curran209
It seems that Linuxcnc had supported it? I read that in wiki.linuxcnc.org/cgi-bin/wiki.pl?Emcrsh.
31 Jul 2021 20:33 #216488 by andypugh
If you can get Windows to open a network socket, and get the UI to send messages, then it ought to work.
There is documentation here: linuxcnc.org/docs/2.8/html/man/man1/linuxcncrsh.1.html
02 Aug 2021 07:37 #216669 by curran209
Had you use linuxcncrsh? Is linuxcncrsh work ok?
02 Aug 2021 11:53 #216687 by andypugh
I have only experimented with it very briefly.
I think that you can assume that it works, but would need to check whether all that you want to do can be done through it.
If you require more then possibly you should look at Machinekit, they have "Machinetalk" which seems to be aimed at this sort of remote-GUI task.
Time to create page: 0.069 seconds
