Jog pendant moves x and y axis at the same time
- ricowind67
30 Jul 2021 17:57 #216371
by ricowind67
Jog pendant moves x and y axis at the same time was created by ricowind67
on my Older probotix the jog pendant is moving 2 axis at the same time, it has always worked well until lately.
any ideas?
any ideas?
- Thank you received: 4652
31 Jul 2021 20:53 #216493
Replied by andypugh on topic Jog pendant moves x and y axis at the same time
Use halmeter (you can open multiple ones) to see if the axis.x.jog-enable pins of more than one axis are set true.
And if they are, then work out why. Probably a problem in the pendant.
Time to create page: 0.081 seconds
