Ohmic sensor and thcad 10
- paulsao
- Thank you received: 22
30 Jul 2021 18:21 #216375
by paulsao
Ohmic sensor and thcad 10 was created by paulsao
Hello group I am trying to make the hypersensitivity circuit with thcad-10, in the diagrams I see that they use a ponwer source of 24v + and 24v-, I want to know if I can use a source only of 24v + and with what resistance would I use it, I am about to finish and it would be great help in this matter.
- Thank you received: 7468
30 Jul 2021 18:54 #216376
Replied by tommylight on topic Ohmic sensor and thcad 10
They use a simple 24V supply, normaly they have + and - written on them.
The dual power supplies must have 3 terminals for common, positive and negative.
The following user(s) said Thank You: paulsao
- paulsao
30 Jul 2021 22:26 #216406
by paulsao
Replied by paulsao on topic Ohmic sensor and thcad 10
Thanks for the answer, now that I'm putting together another question, if I use hypersensitivity with thcad-10 for sensing, do I need another thcad card? Because in the inputs in + and in - the voltage division enters and in the sensor ohmic in these inputs the torch and the table are used, I am confused.
- bevins
- Thank you received: 338
30 Jul 2021 22:56 #216409
by bevins
Replied by bevins on topic Ohmic sensor and thcad 10
If you are using thc with a thcad and want to do ohmic sensing you need another thcad.Thanks for the answer, now that I'm putting together another question, if I use hypersensitivity with thcad-10 for sensing, do I need another thcad card? Because in the inputs in + and in - the voltage division enters and in the sensor ohmic in these inputs the torch and the table are used, I am confused.
- paulsao
30 Jul 2021 23:06 #216411
by paulsao
Luckily I have another one, now I need to know which is the pin of the thcad which gives the signal to the mesa card that the metal is already sensed
- Thank you received: 4145
30 Jul 2021 23:38 #216414
Replied by rodw on topic Ohmic sensor and thcad 10
Its not as simple as that. You need to search the forum for ohmic3.comp and connect it via hal before you install Plasmac. Then you connect the output pin from ohmic3.comp to the plasmac input.Luckily I have another one, now I need to know which is the pin of the thcad which gives the signal to the mesa card that the metal is already sensed
- paulsao
31 Jul 2021 16:35 #216466
by paulsao
Ok, I think I go the way of relays and that, in the 5 guidelines of the plasma guides the first point indicates that the torch should always be isolated the tip of it to use this system, what does that refer to and if it is isolated as it would make electrical contact for the ohmic sensor, I am using a lotos lpt5000 plasma ... Sorry for my english.
Time to create page: 0.186 seconds
