job started in different X location than what is on LinuxCNC console and Vcarve
31 Jul 2021 11:48 #216445 by eeyore124
See the attached pictures.  Everything looks good in Vcarve Pro and on LinuxCNC console but the retangle on the right printed in the
wrong location.  I have another job on the CNC with same issue, looks good in Vcarve Pro and LinuxCNC Gui but when I start the job
it homes and then moves to the wrong location to start.  I stoped this and double checked everything in Vcarve re-exported toolpath and
loaded it into LinuxCNC and its doing the same thing.  I can send a video of the current job if that would help.
31 Jul 2021 13:59 - 31 Jul 2021 14:19 #216451 by Aciera
hal, ini and gcode files might help.
Last edit: 31 Jul 2021 14:19 by Aciera.
  • Moderator
  • Moderator
31 Jul 2021 17:38 #216471 by tommylight
31 Jul 2021 20:09 #216483 by eeyore124
Here are the files.  I have a new job that I am working that looks good in VCarve and LinuxCNC but when go to machine the spindle is starting in the wrong location for the X axis.  It should be at the edge of the work and instead its about 4in to the right (Y axis is correct)
31 Jul 2021 20:32 #216487 by eeyore124
I don't have any offsets set in Vcarve.
31 Jul 2021 20:36 #216490 by eeyore124
I do not have any offsets set in Vcarve.
In LinuxCNC I'm using G54 zero the position of the work piece
01 Aug 2021 16:22 #216622 by andypugh
Are all cuts made with the same tool?
It is possible that an X or Y offset has found its way into the tool table, but that would offset all cuts for that tool by the same amount.
01 Aug 2021 17:27 - 01 Aug 2021 17:29 #216635 by MaHa
I have checked the gcode in my sim, and it seems correct. You see the location for X0 / Y0. In your gcode is no work coordinatesystem (G54 to G59.3) set, but by default it is mostly G54. If you jog your tool to the desired starting point and touch off G54 to X0 / Y0. Thats it
Last edit: 01 Aug 2021 17:29 by MaHa.
01 Aug 2021 19:45 #216645 by eeyore124
Thanks you for your response. The machine hit the hard limit on this job, this should not happen. It's setup with soft limit. I cut the material down an inch from 48in to 47in, and was able to run the job. I'm going to go back and double check my hard and soft limits. When it hit the hard limits it was when I interrupted the job and homed the machine.
02 Aug 2021 06:23 #216666 by Aciera
The gcode you attached does not seem to match the part you showed in your picture. The slanted cutouts are not part of it so it seems to me that it must be something you do in between running different gcode files.
Time to create page: 0.762 seconds
