bug / issue with update v2.9.0-pre0-4361-gac03a9aec
  • robertspark
  • Topic Author
  • Platinum Member
  • Platinum Member
5 years 3 months ago - 5 years 3 months ago #216589 by robertspark
something changed in the last 24 hours (updated yesterday, and it was all working fine), updated today, and lccnc won't start.....seems to fall over after loading nativecam (gladevcp)I am using Gmoccapy for a lathe, mill and router configQTPlasmac loads fine
File Name: linuxcnc_2...8-01.txt
File Size:8.89 KB
Last edit: 5 years 3 months ago by robertspark.
5 years 3 months ago #216590 by tommylight
Master moved to Python 3 from yesterday.
No time to check anything for now, sorry.
If you must go back to a working config/machine, download the deb from the buildbot:
  buildbot.linuxcnc.org/dists/buster/master-rtpreempt/
This is the latest build that worked, anything above it will use Python 3.
linuxcnc-uspace_2.9.0~pre0.4177.g14d07b66d_amd64.deb
The following user(s) said Thank You: robertspark
  • robertspark
  • Topic Author
  • Platinum Member
  • Platinum Member
5 years 3 months ago #216591 by robertspark
Replied by robertspark on topic bug / issue with update v2.9.0-pre0-4361-gac03a9aec
yes downgraded and it works fine again no problems, thanks.
5 years 3 months ago #216594 by rodw
Nativecam needs to upgrade to GTK3
gtk2 is end of life, and I announced this change to happen on this date
on the ml about 2 months ago, and I worked on this for over a year.
there were no objections.
sourceforge.net/p/emc/mailman/message/37303177/
all code is gtk3 only now.
  • robertspark
  • Topic Author
  • Platinum Member
  • Platinum Member
5 years 3 months ago #216596 by robertspark
I thought it was nativecam and gtk2/3
.... I have not loaded Gmoccapy without nativecam.... so think it's just nativecam (which I do like and find very useful for simple chained operations)
Time to create page: 0.053 seconds
