Problems with building Linux CNC source
07 Aug 2021 16:14 #217135 by smal
Replied by smal on topic Problems with building Linux CNC source
How does the processor speed affect general performance of the linuxcnc software? How computing intensive is actually linuxcnc? I assume if we have a loop at 1KHz this is not something which any generation of processors produced in the last 15 years can not handle?
07 Aug 2021 16:40 #217138 by robertspark
Replied by robertspark on topic Problems with building Linux CNC source
it's not the frequency it's the consistency.... real time means it needs to be ON TIME with little variance
some are good and some not so good as there are too many peripherals or power saving elements (like laptops).... hence all that is disabled as is speedstep , hyperthreading and c-states in the bios
  • Moderator
  • Moderator
07 Aug 2021 16:54 #217139 by tommylight
Replied by tommylight on topic Problems with building Linux CNC source
LinuxCNC can run even on some very old hardware, i had it running on a P2 @500MHz, still have it running on a AMD Geode @1000MHz, so if you feel lucky search the web for "coolcnc" and "Debian Dog LinuxCNC".
BTW, dissable hyperthreading, it is enabled on the PC you did the compiling, it is very bad for latency, although you are using a Mesa card so it might not matter at all.
07 Aug 2021 19:31 #217155 by smal
Can you go here a little bit more into detail regarding speedstep -> what this is and where is turned off, the same for hyper-threading and c-states. Is this set in the bios?
07 Aug 2021 20:40 #217156 by robertspark
yes, they are all bios settings
21 Jul 2024 04:53 #305744 by vre
Replied by vre on topic Problems with building Linux CNC source
I try to build linuxcnc master (2.10 pre0)
and build goes to infinite loop with these messages repeated continuously
Use of uninitialized value $line in scalar chomp at /usr/share/perl5/Locale/Po4a/Man.pm line 2344.
Use of uninitialized value $line in concatenation (.) or string at /usr/share/perl5/Locale/Po4a/Man.pm line 2345.
Use of uninitialized value $line in pattern match (m//) at /usr/share/perl5/Locale/Po4a/Man.pm line 2346.
Use of uninitialized value $line in pattern match (m//) at /usr/share/perl5/Locale/Po4a/Man.pm line 2347.
  • Moderator
  • Moderator
21 Jul 2024 12:07 #305783 by tommylight
Try compiling without documentation.
Time to create page: 0.224 seconds
