- Thank you received: 6
Classicladder
- mjones@welfab.ca
- Topic Author
5 years 2 months ago #216934
by mjones@welfab.ca
Classicladder was created by mjones@welfab.ca
Hi all.
Im trying to edit my hal and add classic ladder. I have a friend that has the same machine as mine and he has converted his machine to linuxcnc already. I have his hal and his classicladder and when i try altering certain parts it errors, and im starting to think that is because i don't have the interface pannel in the machine yet and its not able to get any signals. Does this sound right? for eg. if i enter the following i get an error saying 'wsum.0.bit.0.in' does not existnet t1-bit0 wsum.0.bit.0.in <= hm2_7i76e.0.7i64.0.4.input-19net t1-bit1 wsum.0.bit.1.in <= hm2_7i76e.0.7i64.0.4.input-20net t1-bit2 wsum.0.bit.2.in <= hm2_7i76e.0.7i64.0.4.input-21net t1-bit3 wsum.0.bit.3.in <= hm2_7i76e.0.7i64.0.4.input-22net turret1-num wsum.0.sum => classicladder.0.s32in-02
its being told to look at 'classicladder.0.s32.in-02 for this. I get that classicladder.0. is the custom.clp in my file now the s32 is that a different classic ladder program or is it how they number rungs in the ladder and in-02 should be input-02 of s32
Can any one confirm if i am right or wrong on this and help me figure out the s32. or if i have to stop working in comfort and hook up the the machine and start configuring out there so the computer can get the input signals its looking for.
- Thank you received: 2181
5 years 2 months ago #216948
Replied by cmorley on topic Classicladder
The error says :
wsum.0.bit.0.in does not exist
Wsum is a component unrelated to classicladder.
Find out my the wsum component's pins are missing.
- mjones@welfab.ca
- Topic Author
5 years 2 months ago #216977
by mjones@welfab.ca
Replied by mjones@welfab.ca on topic Classicladder
the lines below are copied and pasted out of the hal. wsum.0.bit.0.in is in the hal and is tied to hm2_7i76e.0.7i64.0.4.input-19 but error says it doen't exist.
the last line says that wsum.0.sum is tied to classicladder.0.s32in-02 if i take these lines out of hal and open linuxcnc and hall configuration under pins-classicladder i see pin s32in-02. I'm not understanding something here. as far as i can see wsum.0.bit.0.in is there. Im wandering if because its not hooked up to the machine and not getting a signal to the pin if that is the problem?
- Thank you received: 5334
5 years 2 months ago #216980
Replied by PCW on topic Classicladder
do you have a
"loadrt weighted_sum wsum_sizes=blahblah"
statement in your hal file?
- mjones@welfab.ca
- Topic Author
5 years 2 months ago #216981
by mjones@welfab.ca
I didn't, but i do now and it works. thank you for that, I have to pay more attention to that stuff.
