ini file and limits problem
  • mjones@welfab.ca
  • Premium Member
  • Premium Member
05 Aug 2021 19:08 - 05 Aug 2021 19:57 #217004 by mjones@welfab.ca
ini file and limits problem was created by mjones@welfab.ca
Hi Guys
i made some changes to min and max limits and now having a problem with linuxcnc booting, it doesn't give a debug file info.  it says unspecified [AXIS-A]MIN_LIMIT  default used: -1E99  it says this for 'a' min and max and aslo 'y' min and max this is under a warning message then it gives an errow message
'JOINT_3]MIN LIMIT> [AXIS_A]MIN_LIMIT (-16.25> -1E99)
I don't know what default 1E99 is, I have specified a distance, does anyone have any idea what i screwed up now?
Last edit: 05 Aug 2021 19:57 by mjones@welfab.ca.
05 Aug 2021 23:33 #217015 by andypugh
Replied by andypugh on topic ini file and limits problem
Can you attach the INI file?
  • mjones@welfab.ca
  • Premium Member
  • Premium Member
06 Aug 2021 13:30 #217059 by mjones@welfab.ca
Replied by mjones@welfab.ca on topic ini file and limits problem
absolutely.  here are the ini and hal files
File Name: superslant...8-06.ini
File Size:5 KB
File Name: superslant...8-06.hal
File Size:32 KB
06 Aug 2021 18:59 #217069 by PCW
Replied by PCW on topic ini file and limits problem
I suspect its because you have a lower case A in the Axis name:
# Axis A
[AXIS_a] <<<<<<<<<<<<<<<<<<<<<<<<<<<<<
MIN_LIMIT = -16.25
MAX_LIMIT = 0.00
MAX_VELOCITY = 8.3333
MAX_ACCELERATION = 80.0
  • mjones@welfab.ca
  • Premium Member
  • Premium Member
06 Aug 2021 19:18 #217072 by mjones@welfab.ca
Your are as always correct, I changed that and it got past that problem and it moved forward. I still have problems with no route to host, but hopefully I can figure that part out. Its the little things that catch you. These computer things are very picky devices.
Thanks once again, your the best.
