step&direction vs analog
- mjones@welfab.ca
- Thank you received: 6
07 Aug 2021 15:22 #217125
by mjones@welfab.ca
step&direction vs analog was created by mjones@welfab.ca
I am redoing motors and drives and electronics on a 4 axis lathe, I have it wired as step and direction but as i have a 7i77 and a 7i76e on it, I can do either step and direction or analog. Step and direction is easiest enough to understand (thats why I chose it) but am wondering what is the best and most accurate method of controlling ac servo motors.
The gantry mill that i built runs on step and direction and runs accurate.
If any one that is familiar with analog and step and direction has a reason or preference over one or the other I would like to hear it.
Thank you
Thank you
- Thank you received: 7468
07 Aug 2021 16:39 #217136
Replied by tommylight on topic step&direction vs analog
Personally i preffer analog, at least till something happens with STMBL drives.
You should stick to step/dir since you are familiar with it and tuning an analog servo system can be daunting at times.
Also from reading here some reputable servo drives are useles in analog mode as they have huge input lag. Can not mention names as i can not test those claims but i would love to give them a go.
- mjones@welfab.ca
07 Aug 2021 16:59 #217142
by mjones@welfab.ca
Replied by mjones@welfab.ca on topic step&direction vs analog
Thanks for your advise. I likely will stick with step and direction as its already wired that way, just wanted to check and see what was better.
My drives are Lichuan A4 series AC servo drives (chinese). The guy I know that has already redone a lathe like mine has same drives and he went analog. I just don't understand how the analog is controlled, I can only assume that it does it like a frequency drive only it holds it to the encoder count.
I had some extra drives and motors you could have played with but i recently upgraded my mill to AC servo and used them. I need to get more so I have a spare set being as I will have 8 of them in service.
Time to create page: 0.410 seconds
